Workbench Prefs
tommysammy
Workbench Prefs
Post by tommysammy »
There is an option for "close parent automatically"
I wish me a " close child automatically" option
Is it possible to add it?
Hans
Re: Workbench Prefs
Post by Hans »
tommysammy wrote:There is an option for "close parent automatically"
IIRC, there is a non-obvious way to automatically close the parent window. It might be holding down the left Amiga (or is that right Amiga?) when double-clicking on a drawer, but I don't know for sure.
Hans
Re: Workbench Prefs
I think you misunderstood. Thomas knows the RAmiga shortcut for closing the parent as you open a child - he wants to do the opposite, close the child as you "Open Parent".
Sounds like a reasonable request.
Re: Workbench Prefs
tonyw wrote:I think you misunderstood. Thomas knows the RAmiga shortcut for closing the parent as you open a child - he wants to do the opposite, close the child as you "Open Parent".
It's the same shortcut - RAmiga+close gadget - but there's no equivalent to permanently enable this in WB prefs.
Hans
Re: Workbench Prefs
Post by Hans »
True, but the same hotkey opens the parent when you close the child window.
Hans
Re: Workbench Prefs
No it doesn't.
We must be talking about different things. If I select "Open parent" and hold the RAmiga key, the parent opens but the child window does not close.
Similarly, if I click the go-away box whilst holding the RAmiga key, the child window closes but the parent does not open.
Is it different on your machine?
tommysammy
Re: Workbench Prefs
You have understood me :)
Please i don`t want a solution with a hotkey or so, i wish me an option in Workbench Prefs.
Scriptjester
Re: Workbench Prefs
Post by Scriptjester »
tommysammy wrote: Please i don`t want a solution with a hotkey or so, i wish me an option in Workbench Prefs.
Until there is a Workbench Prefs, use this :
http://www.os4depot.net/index.php?funct ... t/cdop.lha
I know : it's a hotkey ! But useful...
imagodespira
Re: Workbench Prefs
Post by imagodespira »
If i understand you right, you want to open a window. Then open a drawer within and the "parent" window should close that there is only the opened drawer left?
Look in Workbench Prefs on the first Tab, right side in "Option". The first entry is in german "Übergeordnetes automatisch schließen", in english should be "close parent" ;)?
Is this for what you are looking?
I use it since years in addition with a arrex script which openes the parent window again if i hit my configured mouse button.
tommysammy
Re: Workbench Prefs
imagodespira wrote:If i understand you right, you want to open a window. Then open a drawer within and the "parent" window should close that there is only the opened drawer left?
I know that but this is not I am looking for. I have this already enabled.
