urlopen prefs
JosDuchIt
urlopen prefs
Post by JosDuchIt »
I have lost time to find where you could set the urlopen prefs (url )
Now i tried to change the settings (adding Odyssey browser) with no succes.
Whether i try to change an existing line or add a new browser, an entered string (cloënt name, cliënt path) always disappears or gets back to NETSURF when entering the next string of the same line.
There seems to be something wrong with the edit mode.
Re: urlopen prefs
JosDuchIt wrote:I have lost time to find where you could set the urlopen prefs (url )
Add New Client
Type in the name of the program and press ENTER
Works for me
JosDuchIt
Re: urlopen prefs
Post by JosDuchIt »
@Raziel
Thanks for the fast reply: Works for me too. :)
I used the TAB key though, i did not expect either that just entering the application would generate the right command lines everywher too (they are different for the different browsers )
The urlopen.doc was no help though in the above problems, some mention of where the prefs are and how to use them would be useful.
Using the TAB to move into prefs settings and at the end hitting some OK button or the return key is indeed what users expect.
Re: urlopen prefs
JosDuchIt wrote:@Raziel
Yeah, there was some talks about it, sGrab and probably far more software do it the same way and it's considered proper coding (from a porgrammers pov) :-)
If you want, take a look here
