ClockData <-> TimeStamp
mritter0
Post by mritter0 »
I would like to see some new utility.library functions be added to help out in date conversions:
DateStamp=ClockData2DateStamp(struct ClockData clockdata)
ClockData=DateStamp2ClockData(struct DateStamp *datestamp)
Why? Because FormatDate() uses a DateStamp only. Or add a FormatDateCD() that can convert ClockData to the same template.
FormatDate(Locale,"%d-%b-%y %T",dateStamp,&putCharHook);
FormatDateCD(Locale,"%d-%b-%y %T",clockData,&putCharHook);
colinw
Re: ClockData <-> TimeStamp
Post by colinw »
Use the "AmigaTime" as the standard interchange data type, which is; (uint32) Seconds {since the 1st,Jan,1978}
and then convert it to and from the different structures with the appropriate library functions. ie;
The timer.device normally operates on "AmigaTime" via a struct TimeVal {uint32 Seconds; uint32 Microseconds;}
The DOS library also has; IDOS->DateStamp( struct DateStamp *ds ); Which also can return "AmigaTime". (seconds) in IoErr().
The utility library has the AmigaTime to ClockData convertor functions;
uint32 seconds = IUtility->Date2Amiga(struct ClockData *cd);
void IUtility->Amiga2Date(uint32 seconds,struct ClockData *cd);
Then you have the other DOS functions to convert between AmigaTime and DOS DateStamps;
struct DateStamp *ds = IDOS->SecondsToDateStamp( uint32 seconds, struct DateStamp *ds );
uint32 seconds = IDOS->DateStampToSeconds( struct DateStamp *ds );
You also have the date formatting function that are in DOS;
int32 success = IDOS->DateToStr( struct DateTime *datetime );
int32 success = IDOS->StrToDate( struct DateTime * datetime );
Enjoy...
mritter0
Post by mritter0 »
SecondsToDateStamp() was what I was missing. Thank you.
