BUTTON_AutoButton
mritter0
BUTTON_AutoButton
Post by mritter0 »
Could you add BAG_POPDATE to the list of built-in BUTTON_AutoButton images? A calendar image of some sort.
salass00
Re: BUTTON_AutoButton
Post by salass00 »
There's a BAG_POPTIME. Have you tried using that?
mritter0
Post by mritter0 »
That's what I am using; calendar just more accurate for what the gadget is for. I will probably switch to a PNG image down the road. Just asked for completeness.
salass00
Post by salass00 »
A requirement for BAG_POPDATE is that support for GLYPH_POPDATE and an appropriate DrawList based vector image would need to be added to glyph.image first. I'd do it but I'm not sure if I can make a calendar image that will be recognisable as such.
salass00 wrote:A requirement for BAG_POPDATE is that support for GLYPH_POPDATE and an appropriate DrawList based vector image would need to be added to glyph.image first. I'd do it but I'm not sure if I can make a calendar image that will be recognisable as such.
A small grid with the last line missing the last couple of squares would probably do it.
salass00
Post by salass00 »
chris wrote: A small grid with the last line missing the last couple of squares would probably do it.
First attempt:
Good enough?
Fits perfectly to the other buttons, if i were asked
Petrol
Post by Petrol »
Nice work!
Is it possible to lock aspect ratio to avoid enlargement of the glyph inside the button?
The best would to allow to use custom graphics (vector or bitmap)!
regards,
trixie
Post by trixie »
Petrol wrote:Is it possible to lock aspect ratio to avoid enlargement of the glyph inside the button?
CHILD_WeightedHeight, 0,
CHILD_WeightedWidth, 0,
The Rear Window blog
mritter0
Post by mritter0 »
Works for me.
