Update 3 USB Crashes on launch
danwood
Post by danwood »
I posted this on Amigaworld.net too, but just installed Update 3 and now my machine crashes every time I plug my keyboard in:
http://i.imgur.com/h7lgt.jpg
It did work briefly for a minute after a reboot but then the crash happened again. I've tried rebooting without keyboard plugged in and the system is fine, but as soon as it's plugged back in, same crash.
I have an A1XE, I use an Apple slimline keyboard. Any ideas?
Rigo
Re: Update 3 USB Crashes on launch
Post by Rigo »
Let's take this one step at a time then.
As the AmigaOne doesn't have EHCI hardware, I assume you have a PCI card, what type/chip does it use?
Secondly, does your keyboard work OK if plugged in to one of the OHCI ports?
Simon
danwood
Post by danwood »
Rigo wrote:Let's take this one step at a time then.
Simon
Hi Rigo, thanks for the prompt reply
Yes I use a PCI Card, it's not got a brand on it but the chip is a VIA VT6212L
My on-board ports seemed to stop working a few years back, that's what prompted the purchase of the card which has worked fine since.
I've tried attaching the Dell keyboard from my Windows PC and that seems to work fine, so seems to be a conflict with the Apple keyboard?
Rigo
Post by Rigo »
Hmm, well, I don't own an Apple keyboard, so I can't test that here, but I know there are a few people on here that do, so it might be best to see what others find when they install update 3.
It might be a problem with the USB card, many chip vendors supply errata due to their buggy chip designs :/
Simon
danwood
Post by danwood »
Is there any simple way to revert to the Update 2 USB driver in the mean time?
Rigo
Post by Rigo »
You could simply remove the ehci driver from your kicklayout, that should do it.
Simon
danwood
Post by danwood »
This is my USB card:
http://i.imgur.com/Z6Xp3.jpg
danwood
Post by danwood »
Rigo wrote:You could simply remove the ehci driver from your kicklayout, that should do it.
Simon
Excellent I'll give that a go :)
danwood
Post by danwood »
Simon
Unfortunately my system won't boot at all without the file:
http://i.imgur.com/lhiOT.jpg
rwo
Post by rwo »
You need to edit the sys:kickstart/kiclayout file
here you need to find the line where 'MODULE Kickstart/ehci.usbhcd' is
when you found that you put a ';' at the begining of the line, this will stop the loader from loading the file.
RWO
