I encountered an annyoing behaviour in Notepad's search window.
I know of this actually for a long time, but only recently figured that it was not me, but the search window playing tricks on me.
Once you did an unsuccesfull search, the top bar of the search window will change to '"blahblah" not found'.
Now, if you type in a new search and type something very long.
In the meantime of typing the top bar result will change back to "Search", kicking you out of the search field...which is, to say at least, impudent
On a larger scale it's flat annoying...can something be done about it, please?
Steps to reproduce:
1) Load in a text file
2) Click on "Search" and enter "something" in the search field. It's important that it does not find it
3) Be sure to also set "From top", as if it seems that with this checkmark set, it always happens
4) When the top bar of the Search window has changed to '"something" not found', click again in the search field and start typing
5) Keep typing while you wait for the Search window's top bar to change back to "Search" and see getting kicked out of the search field or even some different behaviours (see below)
The behaviours i've witnessed so far:
1) It kicks you out of the search field (cursor gone) and never lets you type along until you click into the search field again (very often)
2) It stalls your input for a moment (2-3 seconds), then goes on processing your input, but with lots characters (the ones you typed while it stalled) (very seldom)
3) It keeps on processing your inputs without stalling and working fine (very seldom) - actually this kind of behaviour can be prevented completely by setting the "From top" checkmark
