I would like to get OS 4.1 running on my A3000T. I had 4.0 running on it when it was first released, but didn't upgrade when 4.1 came out because of lack of memory on my CS-PPC. Now when I try to boot the machine all I get is a flash on the video monitor while the keyboard Caps Lock light flashes just once. This happens with either the accelarator in place or not. Someone suggested that my m/b may need to be re-capped. If so where in the States is a good place to have that done? Also I would be appreciative if anyone could give me a link to a less drastic step first.
Val
OS 4.1 on A3000T
- Valiant
OS 4.1 on A3000T
A1-XE, 800Mhz G4, 512Mb
Sam440ep, 666Mhz, 512Mb
A1-X1000, 1.6Ghz PA6T, 4Gb
- danbeaver
Re: OS 4.1 on A3000T
There is a Mac guy who will replace the caps for $55 in Michigan but he can't test the Motherboard afterwards (www.maccaps.com). I've used him on a known working board with audio issues and now its great; I used Anthony Hoffmen to repair and recap around 5 motherboards, which he repairs and fully tests each. He works in the Antarctic until Nov 2015, so you might try Amigakit. Otherwise you could just ask in the Wanted Forums for someone who has the experience to do the diagnostics and repair.
- DarrenHD
alenppc on english amigaboad (he's in Montreal) repaired 6 of my motherboards, including two A4000T. Did a great job. Look him up, very reasonable prices.Valiant wrote:I would like to get OS 4.1 running on my A3000T. I had 4.0 running on it when it was first released, but didn't upgrade when 4.1 came out because of lack of memory on my CS-PPC. Now when I try to boot the machine all I get is a flash on the video monitor while the keyboard Caps Lock light flashes just once. This happens with either the accelarator in place or not. Someone suggested that my m/b may need to be re-capped. If so where in the States is a good place to have that done? Also I would be appreciative if anyone could give me a link to a less drastic step first.
Val
