I did not see this mentionned anywhere in the AOS4.1 package so is there a floppy usage guide for classic ?
What I see is that the floppy drive is supported and the floppy disk I would insert shows up its icon on the WB and I can open it BUT
- this works only if I insert the floppy disk and reboot
- ejecting the disk and inserting another one does not get rid of the previous icon
- inserting a floppy disk once the WB is loaded does not shows up the floppy disk icon
I tried mounter in system folder but it simply ignores the trackdisk.device
so how to load/eject floppy disk then ?
floppy disk usage guide ?
- DarrenHD
Re: floppy disk usage guide ?
Hi, what system do you have? There are some differences in the floppy drive handling based on what type of Amiga you have - A1200 from C= vs. A1200 from Escom/AT, or A3/4000. There are some questions asked suring the OS4.1 Installation about that.Lio wrote:Hi All,
Darren
yes you re right, I have the original A1200 from Commodore so I did not apply the fix during installation (it was automatically chosen anyway AFAIR).
- DarrenHD
Okay, then the floppy behaviour should be the same as it is on OS 3.9, eg. the floppy Icon should appear - or disappear - if you insert or eject the disk.Lio wrote:yes you re right, I have the original A1200 from Commodore so I did not apply the fix during installation (it was automatically chosen anyway AFAIR).
you can also try the diskchange df0: command from shell.
Darren
as I said if I dont insert a disk at boot, no disk icon appears and a diskchange DF0: gave a insert DF0: !
it works ONLY if a disk is inserted at boot and only in this case, the diskchange command is working... I guess I have to live with that !
Rotzloeffel
There is an entry at the end of the file Kicklayout-A1200. You find it in Devs:Kickstarts/
uncomment the Line A1200FloppyFix
that should solve your Problem
