Checkbox in requester.class
mritter0
Post by mritter0 »
Could you add a checkbox option to the requester.class? Put it under the integer/string gadget, box first then the text.
Requester=NewObject(RequesterClass,NULL,
    REQ_TitleText,        "Title",
    REQ_Type,              1,                                       // integer
    REQ_BodyText,        "Enter tab size",
    REQ_GadgetText,    "OK|Cancel",
    REQI_Number,         4,
    REQCB_Checkbox,    TRUE,                                // if even needed.  REQCB_Text would "turn it on"
    REQCB_Checked,      TRUE,
    REQCB_Disabled,      FALSE,                               // for certain instances
    REQCB_Text,            "Enable auto indent",
TAG_END);
