I may have access to another A1XE motherboard that has a G4 Megarray cpu module but has issues with the mainboard. I also have a micro a1c, and was wondering if the G4 CPU from the A1XE could be installed onto the micro a1c without problems?
I know they are supposed to use the same CPU connector but I don't want to destroy everything through experimentation.
Does anyone know what would happen if a Micro A1C motherboard with a G4 cpu module from an A1XE connected would work?
Thanks!
Possible to use an A1XE G4 cpu module on u-A1C?
themamboman
Re: Possible to use an A1XE G4 cpu module on u-A1C?
Yes, it will. You will need to check and change the vcore settings on the micro to suit the G4 CPU though.
Simon
Simon
