I managed to build in a catweasel 2 controller in X1000.
So far it works fine. however, any Diskette changes are not recognized and I have to reboot the X1000.
That cannot be normal to reset the machine everytime i make a diskchange.
Crossdosfilesystem here is 53.11 ! Is it nessescary to patch that file also as indicated in the papers?
What else to do ?
Diskchange with catweasel 2
- thomasrapp
Re: Diskchange with catweasel 2
c:diskchange command does not work?
- Christopher Follett
- AmigaKit
You haven't got something setup right. It always detects disk changes, sometimes it can be a bit slow, but no more than 5 seconds.papaoskar wrote:I managed to build in a catweasel 2 controller in X1000.
What else to do ?
__________________
New Products
Thank you for the tip with c: diskchange, it does work! Great enhancement.Christopher Follett wrote: You haven't got something setup right. It always detects disk changes, sometimes it can be a bit slow, but no more than 5 seconds.
I have done the setup as proposed in the manual. Could I have something overseen?
Makes it sense to install it from diskette a second time?
There's probably something interfering the diskchangepapaoskar wrote:Thank you for the tip with c: diskchange, it does work! Great enhancement.Christopher Follett wrote: You haven't got something setup right. It always detects disk changes, sometimes it can be a bit slow, but no more than 5 seconds.
What dosdriver do you start?
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
These are the DosDrivers and the files which seem of importance to me:Christopher Follett wrote: You haven't got something setup right. It always detects disk changes, sometimes it can be a bit slow, but no more than 5 seconds.
Verzeichnis "c:" an Sonntag 10-Aug-14
dismount 6204 ----rwed 14-Mär-13 16:37:51
1 Datei - 6K Bytes - 14 Blöcke verwendet
diskchange 1672 ----rwed 14-Mär-13 16:37:51
: DiskChange 52.2 (10.12.2007)
1 Datei - 1K Byte - 5 Blöcke verwendet
Verzeichnis "devs:dosdrivers" an Sonntag 10-Aug-14
Copy_of_RAD.info 8377 ----rw-d 07-Apr-13 18:05:00
Copy_of_RAD 1057 ----rwed 14-Mär-13 16:41:18
RANDOM.info 8593 ----rw-d 05-Apr-13 18:51:13
RANDOM 89 ----rwed 14-Mär-13 16:41:18
AUX 277 ----rwed 14-Mär-13 16:38:00
AUDIO.info 11579 ----rw-d 05-Apr-13 18:51:13
AUDIO 160 ----rwed 14-Mär-13 16:38:00
IPP1 142 ----rwed 24-Mai-13 21:28:27
IPP0 142 ----rwed 05-Mai-14 15:38:00
IPP1.info 14904 ----rw-d 05-Mai-14 16:01:04
IPP0.info 14904 ----rw-d 05-Mai-14 16:00:20
URL.info 6599 ----rw-d 05-Apr-13 18:51:13
URL 360 ----rwed 14-Mär-13 16:38:00
TEXTCLIP.info 7523 ----rw-d 05-Apr-13 18:51:13
TEXTCLIP 169 ----rwed 14-Mär-13 16:38:00
AUX1.info 6599 ----rw-d 05-Apr-13 18:51:13
AUX1 278 ----rwed 14-Mär-13 16:38:00
AUX.info 6599 ----rw-d 05-Apr-13 18:51:13
td0 542 ----rwed 16-Jul-13 15:20:26
PRT.info 8745 ----rw-d 05-Apr-13 18:51:13
PRT 194 ----rwed 14-Mär-13 16:38:00
PIPE.info 6601 ----rw-d 05-Apr-13 18:51:13
PIPE 137 ----rwed 14-Mär-13 16:38:00
PAR.info 8745 ----rw-d 05-Apr-13 18:51:13
PAR 195 ----rwed 14-Mär-13 16:38:00
td0.info 6862 ----rwed 16-Jul-13 15:20:26
26 Dateien - 117K Bytes - 276 Blöcke verwendet
Hope that helps!
Looking through my Catweasel installation and TD0 is the only one that actually talks to the catweasel by mounting a driver for DF0:
Could you post it's contents?
Should be the very same if you haven't change anything though
Next question, did you start Catweasel prefs, altered it to match your system and saved?
Because there could be a slight chance that the default setting uses either a differnet drive model or a different diskchange command (Pin 34) than what your drive supports.
My Disk 0 ist set to "3,5" High Density (Standard PC drive)"
If you got an original Amiga drive you need to adapt the setting, of course
Sleep Time is set to 6 and Pin 34 is set to DSKCHG
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- AmigaKit
I set it up so DF0 in dos drivers does it, never really used TD0.Raziel wrote:Looking through my Catweasel installation and TD0 is the only one that actually talks to the catweasel by mounting a driver for DF0:
__________________
New Products
Your hint was a really GOOD ONE.Raziel wrote:Looking through my Catweasel installation and TD0 is the only one that actually talks to the catweasel by mounting a driver for DF0:
I have drawn the DF0: driver from Storage to DosDrivers, checked that diskchange was marked and made a 'reboot fast'.
The X1000 booted quick an without a diskette in catweasels drive. Before I could only boot when a diskette was in the drive.
Thank you. All works well now.
- AmigaKit
Hmmm,papaoskar wrote:Your hint was a really GOOD ONE.Raziel wrote:Looking through my Catweasel installation and TD0 is the only one that actually talks to the catweasel by mounting a driver for DF0:
If you have the official release driver, then DF0: should be installed in dosdrivers by default.
__________________
New Products
