printertofile.device versus CMD
JosDuchIt
Post by JosDuchIt »
CMD does not seem to have made it to OS4, and hunting for it i found that printertofile.device is probably seen as its replacement.
With CMD you were able to run it from shell and specify the file that should be used as outputn when printing to PRT:
This is not possible it seems with printertofile.device which always will present a filerequester. This is really less handy.
Do i overlook a possibility?
