A1-X1000: Debian64
A1-X1000: Debian64
If you install Debian on your A1-X1000, then you get a 32-bit userland with a 64-bit kernel. But it is possible to install a 64-bit userland. :-)
Please install the following packages:
1. debootstrap
2. libc6-ppc64
3. libc6-dev-ppc64
4. socat
Setting up a ppc64 chroot on your ppc32 system:
debootstrap --no-check-gpg --arch=ppc64 --variant=buildd sid /chroots/sid-ppc64 http://ftp.de.debian.org/debian-ports
chroot /chroots/sid-ppc64
mount -t proc proc /proc
Install the 'debian-ports-archive-keyring' package:
apt-get install debian-ports-archive-keyring
apt-get update
apt-get install xorg
Close your 64-bit chroot environment:
exit
If you want to use your X server for the chroot environment, then you have to open a TCP port for the chroot X clients:
socat -d -d TCP-LISTEN:6000,fork,reuseaddr,range=127.0.0.1/8 UNIX-CONNECT:/tmp/.X11-unix/X0
Start your 64-bit chroot environment with X11 support:
DISPLAY=127.0.0.1:0.0 chroot /chroots/sid-ppc64
And now you can use 64-bit programs on Debian. :-)
tommysammy
Re: A1-X1000: Debian64
Post by tommysammy »
Nice is it for Ubuntu possible too?
tommysammy wrote:Nice is it for Ubuntu possible too?
I'm not sure but I think it could be possible.
Iceweasel 64-bit on the Debian 64-bit chroot environment:
The 64-bit and 32-bit version of Iceweasel side by side:
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Cool! :-)
Do you notice any performance difference between the 32-bit and 64-bit versions?
Trevor
I'm just Breezin'
trevordick wrote:Cool! :-)
Trevor
Until not now but I'm going to investigate this.
