Optimal CFE-settings for 4.1 and Linux
johnfante
Post by johnfante »
I have a feeling that my CFE settings are not optimal for Linux especially:
At the present they are:
name=options
little-endian?=
ETH0_HWADDR=00:50:C2:20:DA:47
os4_commandline=DEBUGLEVEL=0 SERIAL
MENU_0_LABEL=AmigaOS 4.1
MENU_1_LABEL=AmigaOS 4.1 CD
MENU_1_COMMAND=setenv amigaboot_quiet Y ; boot -fs=iso atapi0.0:amigaboot.of
MENU_0_COMMAND=setenv amigaboot_quiet Y ; boot -fs=amigafs ide0.1:amigaboot.of
speed=set pmu -astate=A4
STARTUP=speed ; menu
MENU_3_LABEL=Ubuntu 12.04 LTS
MENU_3_COMMAND=setenv bootargs "root=/dev/sda9 raid=noautodetect" ; boot -elf -noints -fatfs cf0:vmlinux-3.13.12
framebuffer=800/600/8/0xb0000000/800
BOOT_CONSOLE=pcconsole0
CFE_VERSION=PAS-2.0.30
CFE_BOARDNAME=NEMO
CFE_MEMORYSIZE=4096
amigaboot_quiet=Y
I am especially curious about theese three. I have tried the manual but so far found no answer.
Is this necessary and how do I remove it? I do not have a debug output setup.
Should this be: framebuffer=800/600/8/0x90000000/832
CFE_MEMORYSIZE=4096
Should this be: CFE_MEMORYSIZE=8192
X5000 :-)
Re: Optimal CFE-settings for 4.1 and Linux
Hi John,
JohnFante wrote:I have a feeling that my CFE settings are not optimal for Linux especially:
MENU_8_LABEL=Lubuntu 12.04.4 Kernel 3.13.12
MENU_8_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb1 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.13.12
This is a boot entry of my Lubuntu 12.04.4. "set pmu -astate=4" isn't necessary for you. It's only for my attempts. You don't need the argument "raid=noautodetect". The rest is OK. If you want a splash screen, then add "quiet ro splash' to your bootargs.
JohnFante wrote: I am especially curious about theese three. I have tried the manual but so far found no answer.
Don't worry about it. It's not necessary to remove it.
I have the following framebuffer entry:
But I don't have any knowledge about this entry. I think this is the CFE screen resolution.
JohnFante wrote:
CFE_MEMORYSIZE=4096
Do you have 8GB installed in your X1000?
Furthermore a lot of fun with your A1-X1000. :-)
johnfante
Post by johnfante »
Thank you. I will try that boot argument tomorrow :-)
I have 4GB installed.
X5000 :-)
If you don't have a serial cable to another computer with a terminal program, you can have the debug output directed to a circular (fixed-size) memory buffer instead, which can be dumped using the DumpDebugBuffer command.
This is the default, so you only need to remove the SERIAL keyword, and the way to do this is to enter into the CFE commandline: "setenv -p os4_commandline debuglevel=0".
