Corrupt image in Printer Prefs Settings Tab
The example image displayed like it would be on a page is corrupted on my 16 bit WorkBench screen. The smaller image on the left looks normal. The one on the right which simulates the appearance on a page is white with vertical blue stripes. I never had that corruption on my SAM Flex. I have always used a 16 bit screen for WorkBench and never had that corrupted image on my µA1 or SAM. Did the image change or is this yet another X1000 graphics issue? Can anyone else confirm the problem?
Re: Corrupt image in Printer Prefs Settings Tab
Thanks for confirming. At least I know it's not my system; it's a bug that will hopefully be fixed.ZeroG wrote:Confirmed.
I get a black & white image with the public Printer prefs, but a normal color image with my beta system prefs. I'll keep an eye on it, but looks like its a non issue now, unless another beta tester says different.
- Hans
That looks like the old "can't do misaligned accesses to VRAM on the A1-X1000" problem.
Hans
Good to hear.sundown wrote:I get a black & white image with the public Printer prefs, but a normal color image with my beta system prefs. I'll keep an eye on it, but looks like its a non issue now, unless another beta tester says different.
Hans
- danbeaver
To see the problem, I had to switch to a 16-bit WorkBench and not all printers defined have this issue; I see it with the HP LaserJet, but not the HP Photo smart, nor the File. PostScript shows now image at all as does Generic. Could it be a printer definition problem and not the printer preferences program?
After examining the problem again, I've discovered that the bad image depends on the shade and scaling settings. Possibly your Laserjet and Photosmart settings are different for shade & scaling.danbeaver wrote:To see the problem, I had to switch to a 16-bit WorkBench and not all printers defined have this issue; I see it with the HP LaserJet, but not the HP Photo smart, nor the File. PostScript shows now image at all as does Generic. Could it be a printer definition problem and not the printer preferences program?
If the "Shade" is set to black and white or one of the greyscale settings, the image is corrupt regardless of the "Scaling" settings. The image corruption is simply different for the Fraction and Integer "Scaling".
if the "Shade" is set to Color then the image is correct if "Scaling" is Integer. If the "Shade" is set to Color and the "Scaling" is set to Fraction then the image has a wide vertical line down the center.
