Hello,
I'm experiencing some problems when I soft reboot my x1000 / HD6670 / R9250.
Sometimes (around 1 time on 3 warm reboot ) when I warm reboot, my Workbench doesn't reload (no intro sound) and I'm stuck on a black screen.
According to the readme of the RadeonHD 1.0 (that I have installed) :
"...this solves the intermittent boot problems with some Sapphire Radeon HD6570 cards (and possibly others) and soft-reset problems with some Sapphire Radeon HD 6870 cards."
Is somebody encounters this problem too ?
Is it because HD6670 is not fixed by this RadeonHD 1.0 driver ?
Or is the problem completly different and not related to RadeonHD driver ?
Thank you for your reply (and thank you Raziel and Jabirulo to have spotted me the RadeonHD driver readme)
Guillaume
Soft reset problem with X1000 + HD6670 + RadeonHD 1.0
Re: Soft reset problem with X1000 + HD6670 + RadeonHD 1.0
It would really, REALLY, no really, really helping you if you could set up a serial connection to catch the reason why it's freezing
Maybe it's not about the radeon driver but some other part of your hardware?
Maybe it's your internet connection waiting?
Try to comment out AddNetInterface in s/Network-Startup
(You won't have internet afterwards, but you could test a few reboots if it still freeze for you)
But if are not able to see what is really going on we are fishing in the dark
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
Serial grabbed with "os4_commandline=SERIAL DEBUGLEVEL=5" and standard kernel.
I done
1) Cold Boot,
see
zzd10h *******************************************
zzd10h COLD BOOT
in the debug log
2) and a warm boot just after the initialisation.
see
zzd10h WARM BOOT
in the debug log
http://zzd10h.amiga-ng.org/X1000/Debug_ ... oot_KO.log
My question was too, am I alone to have this problem ?
I done
1) Cold Boot,
see
zzd10h COLD BOOT
in the debug log
see
zzd10h WARM BOOT
in the debug log
Just an idea...what are your Screenmode settings?
Have you tried using "Detect settings automatically"?
I have never seen so many "screenmode not supported" messages...maybe it just can't access the screenmode you chose?
edit: otoh those ERROR CNPs right before it stops logging might give someone with more insight an idea
People are dying.
How dare you!
– Greta Thunberg
How dare you!
– Greta Thunberg
- Hans
@zzd10h
The bit you quoted from the readme is regarding to initial booting. Some cards would intermittently boot to a black screen. It was a really weird bug. My Sapphire Radeon HD 6570 had no trouble, but other people with the exact same model did.
This is a different problem to your soft-reboot issue. Unfortunately, these cards were never designed to be soft-rebooted. Some Radeon HD 6xxx cards will cause a machine check exception (which normally means hardware failure) on a soft-reset. So far I have been unable to find a workaround.
BTW, it's not guaranteed that it's your graphics card stopping the soft-reboot. There may be timing related issues with other software.
Hans
Hans
- Hans
That debug output is just Picasso96 rejecting a whole bunch of unneeded and low-resolution modes. Since this happens every time, this won't be causing any trouble.Raziel wrote:I have never seen so many "screenmode not supported" messages...maybe it just can't access the screenmode you chose?
Hans
Thank you Raziel & Hans,
I understood that it's maybe not related to my gfx card but, by your experience, do you know a card that is less subject to this problem ?
"There may be timing related issues with other software."
Sorry for my unknowledge, what is a timing issues ?
Thank you for your reply (and your work of course)
- Hans
Sorry, but no. I have a 6670 that doesn't have any issues (a single-slot Sapphire). However, that doesn't mean that everyone with the exact same model will have the same experience.zzd10h wrote:Thank you Raziel & Hans,
"Timing issues" is a broad term for problems that can only arise if certain events occur within a particular time period. For example, the 6570/6870 intermittent boot issue was a timing one. The UBoot screen had to be carefully shut down so that the display controllers were disabled during the VBlank period. Otherwise, there was a small window of time where the controller would be put into a hung state, and not start properly when enabled.zzd10h wrote:"There may be timing related issues with other software."
Such issues can also happen where multiple tasks/processes share data. If a suitable locking mechanism isn't used to protect the data, then there can be small windows of time where one task can screw up another's operation. These can be very hard to debug, because the problem usually occurs intermittently.
Hans
Thank you
- danbeaver
Yes, my X1000 has a soft reset problem where I have to use the reset button, but I've pretty much ignored it. I use a 6950 card that works fine otherwise. Often however on a hard reset, I lose USB initialization and can't access the CFE menu, then a power cycle is needed. Don't know if anything is related to anything else, but after 30 years of classic Amiga ownership, I'm used to weird, odd intermittent malfunctions.
