os4 sam440 flex board
This is the place to ask if you have any issues with our forum system. These include questions about your account, PM's, login trouble, etc.
dhey59
Post by dhey59 »
help
I don't know what im do wrong. I load the os 4 software on the system and it says I no slb found and it does back to uboot
my amigaone xe g4 load the os with no problem . all updates applied .
on the sam440 flex the cd didn't come with the board so im using a difference os 4 cd also for sam440 board board is register in my name.
so what am doing wrong I format and loaded the os4 :?:
thanks for all the help got it working.. everyone has been great on here. great site for help
Christopher Follett
AmigaKit
AmigaKit
Re: os4 sam440 flex board
Post by Christopher Follett »
You need to add the SLB boot loader to the HDD RDB in HDToolBOX.
Resolute and Industrious
__________________
New Products
Chris: Don't you mean Media Toolbox?
Boot the CD and select the "Boot to Workbench" button. It will take a few minutes, but after a while the WB should appear. Open Media Toolbox (I think it's an icon in the AmiDock called "Format DIsks" or something like that).
Select the device driver (probably sii3114ide.device), then select your HDD and click the button "Edit RDB/Install".
You have to be careful here. Don't go clicking on buttons at random or you might end up screwing the drive and having to install all over again.
Look down the bottom of the window where it says "AmigaOne boot code (SLB)". The left panel under the title probably says "<not installed>". Click on the button "Install", then select the file "slb_v2" from the L: directory on the CD. MTB will then copy the SLB onto the HDD and you should be right to go. When it has copied it, the left panel should say "l:slb_v2, 29036 bytes, ver 1.19". If that is correct, click "Save".
That should now boot properly.
Christopher Follett
AmigaKit
AmigaKit
tonyw wrote:Chris: Don't you mean Media Toolbox?
Same horse different jokey, ;).
__________________
New Products
