I managed to get the serial debugging working, and now have some output. It boots okay, and I can use for about 7 minutes, and then the screen turns black, and the serial debug says:
[HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.* I've set the debuglevel to 10 in AmigaOS, but it doesn't seem to be a software causing it.
* I've dusted the mainboard off with air duster, removed the RAM stick and cleaned the sockets (and it wasn't terribly dusty to start with)
Does anyone have any suggestions?
Entire serial debug :
[RELO][L1CF][GOLO][GOT ][ZBSS][INIT][MAIN][KMEM][EXCP][CONS][CIOK][AREN][PCIH][PCIB][PCIS][DEVI]
CFE version PAS-2.0.30 for NEMO (64bit,MP,BE,PPC)
Build Date: Fri Jun 8 16:04:49 CEST 2012 (hfrieden@jumpgate)
Copyright (C) 2000,2001,2002,2003,2004,2005 Broadcom Corporation.
Portions Copyright (C) 2005-2008 PA Semi, Inc.
Portions Copyright (C) 2010 Hyperion Entertainment CVBA
Initializing Arena.
Initializing PCI. []
PCI bus 0 slot 17/1: PCIe: port 5 could not be activated
PCI bus 0 slot 17/2: PCIe: port 6 could not be activated
PCI bus 0 slot 17/3: PCIe: port 7 could not be activated
SB600 revision A21 in Intel P4 mode
PCI bus 1 slot 0/0: ATI Technologies product 0x68f9 (VGA display)
PCI bus 1 slot 0/1: ATI Technologies product 0xaa68 (multimedia subclass 0x03)
PCI bus 5 slot 18/0: ATI Technologies product 0x4380 (IDE mass storage, interface 0x8f)
PCI bus 5 slot 19/0: ATI Technologies product 0x4387 (USB serial bus, interface 0x10)
PCI bus 5 slot 19/1: ATI Technologies product 0x4388 (USB serial bus, interface 0x10)
PCI bus 5 slot 19/2: ATI Technologies product 0x4389 (USB serial bus, interface 0x10)
PCI bus 5 slot 19/3: ATI Technologies product 0x438a (USB serial bus, interface 0x10)
PCI bus 5 slot 19/4: ATI Technologies product 0x438b (USB serial bus, interface 0x10)
PCI bus 5 slot 19/5: ATI Technologies product 0x4386 (USB serial bus, interface 0x20)
PCI bus 5 slot 20/0: ATI Technologies product 0x4385 (SMBus serial bus, rev 0x14)
PCI bus 5 slot 20/1: ATI Technologies product 0x438c (IDE mass storage, interface 0x83)
PCI bus 5 slot 20/2: ATI Technologies product 0x4383 (multimedia subclass 0x03)
PCI bus 5 slot 20/3: ATI Technologies product 0x438d (ISA bridge)
PCI bus 5 slot 20/4: ATI Technologies product 0x4384 (PCI bridge)
PCI bus 6 slot 5/0: unknown vendor 0x13f6 product 0x0111 (audio multimedia, rev 0x10)
PCI bus 6 slot 6/0: Realtek Semiconductor 8139 10/100 Ethernet (ethernet network, rev 0x10)
Initializing Devices.
GPIOLV10 Jumper: Not fitted (default VGA console)
GPIOLV11 Jumper: Not fitted (default ?)
PHY: mb, addr 0x00, vendor 03f1 device 15 (1)
GFX: PCIe Slot
GFX: Disable SB600 legacy decode
VGA (1/0/0): ISA memory space mapped to f8000000000
Initializing VGA.
Found 800x600x32 mode: 0x0103 (259)
Current VBE mode is now: 0x0103 (259)
Mode Attribs: 00BB [Graphics] [LinearFrameBuffer]
Resolution: 800 x 600
BitsPerPixel: 8
BytesPerScan: 0x0340
PhysBasePtr: 0x90000000
Enabling ATI frame buffer byte-swap
GFX: PCIe Slot
GFX: Enable SB600 legacy decode
VGA initialization successful.
IDE unit 0: Disk, "ST1000DM003-9YN162", Capacity:931GB (lba48)
ATAPI unit 1: Optical Drive, "TSSTcorp CDDVDW SH-224BB"
PCIIDE: 2 controllers found
Initializing USB.
PCI bus 5 slot 19/5: EHCI USB controller found at A0209800
USB bus 0 device 1: vendor 0000 product 0000 class 09: USB Hub
PCI bus 5 slot 19/0: OHCI USB controller found at A0208000
USB bus 1 device 1: vendor 0000 product 0000 class 09: USB Hub
PCI bus 5 slot 19/1: OHCI USB controller found at A0207000
USB bus 2 device 1: vendor 0000 product 0000 class 09: USB Hub
PCI bus 5 slot 19/2: OHCI USB controller found at A0206000
USB bus 3 device 1: vendor 0000 product 0000 class 09: USB Hub
PCI bus 5 slot 19/3: OHCI USB controller found at A0204000
USB bus 4 device 1: vendor 0000 product 0000 class 09: USB Hub
PCI bus 5 slot 19/4: OHCI USB controller found at A0205000
USB bus 5 device 1: vendor 0000 product 0000 class 09: USB Hub
CPU type 0x900102: 500MHz
Total memory: 0x80000000 bytes (2048MB)
Total memory used by CFE: 0x7FD1DF60 - 0x80000000 (3023008)
Initialized Data: 0x7FDD8420 - 0x7FDF8B00 (132832)
BSS Area: 0x7FDF8B00 - 0x7FDFF000 (25856)
Local Heap: 0x7FDFF000 - 0x7FFFF000 (2097152)
Stack Area: 0x7FFFF000 - 0x80000000 (4096)
Text (code) segment: 0x7FD1DF60 - 0x7FDCBE60 (712448)
Relocation Factor: I:7FE1DF60 - D:7FE1DF60
[ENVI]
[OFW ][UI ]Requested state A4 (1800MHz)
Loader:elf Filesys:amigafs Dev:ide0.0 File:amigaboot.of Options:(null)
Loading: 0x0000000000200000/50812 0x000000000021C67C/76 Entry at 0x0000000000200034
Starting program at 0x0000000000200034
[RUN!] rtg.library AltiVec/VMX enabled
rtg.library PA6T optimizations enabled
RadeonHD (2): Graphics card name is: Radeon HD 5450
RadeonHD (2): Identified the chipset as: CEDAR
RadeonHD (2): If - and only if - your card does not work or does not work optimally
please contact Hans de Ruiter at hans --email-sign-- hdrlab.org.nz to help rectify this.
Use the subject: 0x68F9:0x174B:0xE164: <name of board>
and *please* describe the problems you are seeing
in your message.
RadeonHD.chip (0): Object: ID: 310C name: HDMI_TYPE_A type: 3 id: C
RadeonHD.chip (0): Object: ID: 3102 name: DUAL_LINK_DVI_I type: 3 id: 2
RadeonHD.chip (0): Object: ID: 3105 name: VGA type: 3 id: 5
RadeonHD.chip (0):
RadeonHD.chip (0): --------------------------------------
RadeonHD.chip (0): CONNECTOR TABLE:
RadeonHD.chip (0):
RadeonHD.chip (0): Connector[0] HDMI 1:
RadeonHD.chip (0): Type: RHD_CONNECTOR_HDMI_A
RadeonHD.chip (0): DDC bus: RHD I2C line 1
RadeonHD.chip (0): HPD: RHD_HPD_1 (monitor not connected)
RadeonHD.chip (0): Outputs:
RadeonHD.chip (0): Output AtomOutputUniphyD:
RadeonHD.chip (0): Type: RHD_OUTPUT_UNIPHYD
RadeonHD.chip (0): Device Type: atomDFP1
RadeonHD.chip (0): Device Record: Type: atomDFP1, Connector Type: RHD_CONNECTOR_HDMI_A, ConnectorID: 0xC, EncoderID: 0x20
RadeonHD.chip (0):
RadeonHD.chip (0): Connector[1] DVI-I 1:
RadeonHD.chip (0): Type: RHD_CONNECTOR_DVI
RadeonHD.chip (0): DDC bus: RHD I2C line 3
RadeonHD.chip (0): HPD: RHD_HPD_3 (monitor connected)
RadeonHD.chip (0): Output AtomOutputUniphyA:
RadeonHD.chip (0): Type: RHD_OUTPUT_UNIPHYA
RadeonHD.chip (0): Device Type: atomDFP2
RadeonHD.chip (0): Device Record: Type: atomDFP2, Connector Type: RHD_CONNECTOR_DVI, ConnectorID: 0x2, EncoderID: 0x1E
RadeonHD.chip (0): Output AtomOutputDACA:
RadeonHD.chip (0): Type: RHD_OUTPUT_DACA
RadeonHD.chip (0): Device Type: atomCRT1
RadeonHD.chip (0): Device Record: Type: atomCRT1, Connector Type: RHD_CONNECTOR_DVI, ConnectorID: 0x2, EncoderID: 0x15
RadeonHD.chip (0):
RadeonHD.chip (0): Connector[2] VGA 1:
RadeonHD.chip (0): Type: RHD_CONNECTOR_VGA
RadeonHD.chip (0): DDC bus: RHD I2C line 0
RadeonHD.chip (0): HPD: RHD_HPD_NONE
RadeonHD.chip (0): Output AtomOutputDACB:
RadeonHD.chip (0): Type: RHD_OUTPUT_DACB
RadeonHD.chip (0): Device Type: atomCRT2
RadeonHD.chip (0): Device Record: Type: atomCRT2, Connector Type: RHD_CONNECTOR_VGA, ConnectorID: 0x5, EncoderID: 0x16
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0): RadeonHD card successfully opened
Scanning bus 'HDMI 1'
RadeonHD.chip (0): hw_i2c error (2)
failed.
Scanning bus 'DVI-I 1'
0000: 00 FF FF FF FF FF FF 00 15 C3 13 22 01 01 01 01 ..........."....
0010: 2B 16 01 03 80 33 1D 78 EA EE 95 A3 54 4C 99 26 +....3.x....TL.&
0020: 0F 50 54 A1 08 00 81 80 81 40 B3 00 81 C0 01 01 .PT......@......
0030: 01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C .......:..q8-@X,
0040: 45 00 FE 1F 11 00 00 1E 00 00 00 FF 00 34 30 31 E............401
0050: 38 38 31 30 32 0A 20 20 20 20 00 00 00 FD 00 3B 88102..........;
0060: 3D 1F 44 0F 00 0A 20 20 20 20 20 20 00 00 00 FC =.D.............
0070: 00 46 53 32 33 33 31 0A 20 20 20 20 20 20 00 E6 .FS2331.........
EDID V1.3
ManufacturerID ENC ProductID 2213
SerialNo 16843009 Manufactured week 43 of 2012
Input type digital
Display gamma 2.20
Maximum Image Size 51x29cm
PowerManagement Standby yes Suspend yes ActiveOff yes
Serial Number 40188102
Monitor Name FS2331
Established timings:
800x600@60
640x480@60
720x400@70
1024x768@60
Standard Timing Identification:
1280x1024@60hz (5:4)
1280x960@60hz (4:3)
1680x1050@60hz (16:10)
Not Found: 1680x1050@60hz (16:10) - calling CVT(RB=1)
1280x720@60hz (16:9)
Mode 1920x1080@60hz 67khz
DotClock 148500000hz
HTimings 1920 2008 2052 2200
VTimings 1080 1084 1089 1125
Image Size 510x287mm
Flags progressive +hsync +vsync
Monitor Range Limits:
Horizontal frequency 31 - 68khz
Vertical frequency 59 - 61hz
Pixelclock 150Mhz
sb600sata.device 53.15 (19.2.2012)
sb600ide.device 53.15 (19.2.2012)
UserState in page_sweep from 0x02042998 0x02042A94 0x020426A0
L?rdag 2014-05-10 19.31.46
[elf] .rodata 0x5EB84020-0x5EB8429C H?rddisk:Internet/Odyssey/OdysseyLauncher (sh_flags 0x02) read-only
[elf] .rodata 0x5CDF9020-0x5D031224 H?rddisk:Internet/Odyssey/Odyssey (sh_flags 0x02) read-only
[elf] .gcc_except_table 0x5E764020-0x5E767589 H?rddisk:Internet/Odyssey/Odyssey (sh_flags 0x02) read-only
[elf] .rodata 0x5E93A020-0x5E93A2A8 System:Libs/pthreads.library (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5E93C020-0x5E93C044 System:MUI/Libs/muimaster.library (sh_flags 0x02) read-only
[elf] .rodata 0x5D60F020-0x5D624984 System:MUI/Libs/muimaster.library (sh_flags 0x02) read-only
[elf] .rodata 0x5D5EC020-0x5D5FAD8C System:Libs/codesets.library (sh_flags 0x02) read-only
[elf] .rodata 0x5D3C1020-0x5D3CAF12 System:Libs/expat.library (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D3BD020-0x5D3BD044 System:MUI/Libs/mui/Title.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D3BE020-0x5D3BE2D2 System:MUI/Libs/mui/Title.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D3BF020-0x5D3BF044 System:MUI/Libs/mui/Listtree.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x5D3C0020-0x5D3C09C2 System:MUI/Libs/mui/Listtree.mcc (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D3B0020-0x5D3B0044 System:MUI/Libs/mui/String.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D3B1020-0x5D3B1D28 System:MUI/Libs/mui/String.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D5E9020-0x5D5E9044 System:MUI/Libs/mui/Calltips.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x5D5EA020-0x5D5EA24E System:MUI/Libs/mui/Calltips.mcc (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D5D6020-0x5D5D6044 System:MUI/Libs/mui/Popasl.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D5D7020-0x5D5D7292 System:MUI/Libs/mui/Popasl.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D585020-0x5D585044 System:MUI/Libs/mui/Dtpic.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D586020-0x5D5862CA System:MUI/Libs/mui/Dtpic.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D580020-0x5D580044 System:MUI/Libs/mui/Gauge.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D581020-0x5D581252 System:MUI/Libs/mui/Gauge.mui (sh_flags 0x02) read-only
[elf] .rodata 0x5D582020-0x5D582080 H?rddisk:Internet/Odyssey/LIBS/asyncio.library (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5D494020-0x5D494044 System:MUI/Libs/mui/Lamp.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x5D495020-0x5D495402 System:MUI/Libs/mui/Lamp.mcc (sh_flags 0x02) read-only
[elf] .gcc_except_table 0x5BD52F14-0x5BD562B4 System:Utilities/AmiPDF/AmiPDF (sh_flags 0x02)
has read-only flag in section header
but is located in a read-write section of the program header
(linker (script) error?)
[elf] .rodata 0x5C42B020-0x5C42B282 System:Classes/Gadgets/fuelgauge.gadget (sh_flags 0x02) read-only
[elf] .rodata 0x5B599020-0x5B599332 System:Classes/Gadgets/speedbar.gadget (sh_flags 0x02) read-only
[elf] .rodata 0x5B59B020-0x5B59B9D6 System:Classes/Gadgets/texteditor.gadget (sh_flags 0x02) read-only
[elf] .rodata 0x59C0D020-0x59C64F68 H?rddisk:Kontor/Designer/Designer (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x59EFB020-0x59EFB044 System:MUI/Libs/mui/NList.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x5EEBC020-0x5EEBD1F4 System:MUI/Libs/mui/NList.mcc (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x59AAB020-0x59AAB044 System:MUI/Libs/mui/Coloradjust.mui (sh_flags 0x02) read-only
[elf] .rodata 0x59AAC020-0x59AAC5AC System:MUI/Libs/mui/Coloradjust.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x59AAD020-0x59AAD044 System:MUI/Libs/mui/Boopsi.mui (sh_flags 0x02) read-only
[elf] .rodata 0x59AAE020-0x59AAE266 System:MUI/Libs/mui/Boopsi.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x59F3F020-0x59F3F044 System:MUI/Libs/mui/Colorfield.mui (sh_flags 0x02) read-only
[elf] .rodata 0x59F40020-0x59F40262 System:MUI/Libs/mui/Colorfield.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5DD6A020-0x5DD6A044 System:MUI/Libs/mui/NListview.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x5DD6B020-0x5DD6B27A System:MUI/Libs/mui/NListview.mcc (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x5C738020-0x5C738044 System:MUI/Libs/mui/TextEditor.mcc (sh_flags 0x02) read-only
[elf] .rodata 0x599AD020-0x599AE0F0 System:MUI/Libs/mui/TextEditor.mcc (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x55E2E020-0x55E2E044 System:MUI/Libs/mui/Scale.mui (sh_flags 0x02) read-only
[elf] .rodata 0x55E2F020-0x55E2F266 System:MUI/Libs/mui/Scale.mui (sh_flags 0x02) read-only
[elf] .note.gnu.build-id 0x55E30020-0x55E30044 System:MUI/Libs/mui/Floattext.mui (sh_flags 0x02) read-only
[elf] .rodata 0x55E31020-0x55E3125E System:MUI/Libs/mui/Floattext.mui (sh_flags 0x02) read-only
[elf] .rodata 0x54690020-0x546901F6 System:C/Date (sh_flags 0x02) read-only
[elf] .rodata 0x549FB020-0x549FB1F2 System:Classes/DataTypes/bmp.datatype (sh_flags 0x02) read-only
[RELO][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.[HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][L1CF][GOLO][GOT ][ZBSS][INIT][MAIN][KMEM][EXCP][CONS][CIOK][AREN][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channe?[HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
[RELO][L1CF][GOLO][GOT ][ZBSS][INIT][MAIN][KMEM][EXCP][CONS][CIOK][AREN][HELO][DRAM][HELO][DRAM]SDRAM: ECC off, Non-ECC DIMM used on channel 0.
Initializing Arena.
GFX: PCIe Slot
Initializing VGA.
BitsPerPixel: 8
GFX: PCIe Slot
Initializing USB.
[ENVI]
in your message.
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0):
RadeonHD.chip (0):
failed.
EDID V1.3
Input type digital
Display gamma 2.20
Monitor Name FS2331
800x600@60
640x480@60
720x400@70
1024x768@60
1280x960@60hz (4:3)
Pixelclock 150Mhz
