ReiserFileSystem/03 or example filesystem for 3rd party impl
Belxjander
I'd like to request either of an RFS/03 or example source of a VectorPort filesystem in the SDK where practical/possible.
- colinw
Re: ReiserFileSystem/03 or example filesystem for 3rd party
The tool to create a basic skeleton for the vector-port filesystem DOS interface is available in the latest (hopefully) SDK.Belxjander wrote: I'd like to request either of an RFS/03 or example source of a VectorPort filesystem in the SDK where practical/possible.
It should be; SDK:c/FSVPTool. Just run that in a shell and it will create the source code skeleton for you into ram:.
If you don't have the latest SDK with the fsvptool, I can send it to you, just ask.
We haven't added all the tools to the SDK yet. Sorry for the delay.colinw wrote:The tool to create a basic skeleton for the vector-port filesystem DOS interface is available in the latest (hopefully) SDK.Belxjander wrote: I'd like to request either of an RFS/03 or example source of a VectorPort filesystem in the SDK where practical/possible.
Belxjander
@SSolie: When they are ready and released then I'll make use of them.
