updates
dhey59
updates
Post by dhey59 »
what is the best way to update on amigaone xe.
also what would help is how to do it the easy way. im going to pint this out so I can do it
also im very new to amiga os4
also im at update 1
thank you :?:
ZeroG
Re: updates
Post by ZeroG »
also im at update 1
4.0 Update 1 or 4.1 Update 1?
The correct way to update 4.1 update 1 is:
  • 1. Install Update 2 and make a hard reset (Kickstart must be reloaded)
  • 2. Install Update 3 and make a hard reset
  • 3. Install Update 4 and make a hard reset
  • 4. Install Update 5 and make a hard reset
  • 5. Install Update 6 and make a hard reset
  • 6. Run AmiUpdate (included in Update 6)
  • 7. let AmiUpdate install the updates
  • 8. repeat step 6 and 7 until AmiUpdate does not offer you new updates for the OS.
Re: updates
dhey59 wrote:what is the best way to update on amigaone xe.
also im at update 1
thank you :?:
Hey Don...welcome to the party :-)
@ZeroG
The problem might be that one cannot access any updates before update6 anymore on the hyperion servers.
People are dying.
How dare you!
– Greta Thunberg
ssolie
Re: updates
Post by ssolie »
Raziel wrote:The problem might be that one cannot access any updates before update6 anymore on the hyperion servers.
No updates have been removed. They are all available if you registered your serial number correctly.
Re: updates
Ah, so all earlier updates have vanished maybe because i dropped the XE AmigaOS4 serial number...thanks for the hint :-)
People are dying.
How dare you!
– Greta Thunberg
