openSUSE 13.1
openSUSE 13.1
I've decompressed the X1000 version of the openSUSE 13.1 archive file on my Sam440ep Flex. And then I have copied the Sam kernel 3.14 modules directory to the openSUSE partition. And it boots and works. :-) But there are 2 main problems. I can't configure the network device and X11 has wrong colors. The screenshot above has the right colors. That's strange.
Re: openSUSE 13.1
Nice.
Try the following xorg.conf. This is the original Debian one on Acube's CD that I have used for all my installations.
https://dl.dropboxusercontent.com/u/542 ... .conf-flex
What does your /etc/network/interfaces look like ?
Re: openSUSE 13.1
Spectre660 wrote:Nice.
Thank you. I'll try it in the evening.
Re: openSUSE 13.1
Unfortunately, this xorg.conf doesn't solve the problem with the wrong colors. I've tested it with the kernel 3.14.
The directory /etc/network/interfaces doesn't exist. There is a directory /etc/sysconfig/network. YaST doesn't recognise a network device on my Sam440ep Flex. The command "dhcpcd eth1" works. :-)
Re: openSUSE 13.1
