Hello,
Just a little oversight I've seen in Workbench, if file(s) are selected from a Workbench window programmatically (e.g. through Arexx), yes the window/drawer is opened, but if there are many files in the window/drawer and the selected file(s) are at the bottom of the window/drawer out of view the vertical scrollbar doesn't not 'jump/auto-scroll' to meet the selection. An important usability issue.
Auto-Scroll to Selection
Re: Auto-Scroll to Selection
Try the MAKEVISIBLE argument to the ICON ARexx command in Workbench.
I have the same problem in my programs when I use ChangeWorkbenchSelection() to open a drawer and select a file into it.
Is it a tag that simulates the option MAKEVISIBLE that nbache speak about ?
Thank you
Thank you
- javierdlr
workbench.library/MakeWorkbenchObjectVisibleA workbench.library/MakeWorkbenchObjectVisibleAzzd10h wrote:I have the same problem in my programs when I use ChangeWorkbenchSelection() to open a drawer and select a file into it.
Thank you
NAME
MakeWorkbenchObjectVisibleA -- Change a Workbench window in such a
way as to make a particular icon visible. (V44)
EXAMPLE
// Make the icon for the drawer "SYS:" visible.
MakeWorkbenchObjectVisible("SYS:",TAG_END);
Thank you Javier,
it works very well
it works very well
