The Application Library provides a set of boolean tags through which an app can inform about the features it supports:
REGAPP_HasIconifyFeature
REGAPP_HasPrefsWindow
REGAPP_CanCreateNewDocs
REGAPP_CanPrintDocs
These properties can also be specified after registration, via
APPATTR_HasIconifyFeature
APPATTR_HasPrefsWindow
APPATTR_CanCreateNewDocs
APPATTR_CanPrintDocs
I haven't designed the library and the autodoc is very sketchy on this particular bit, but I believe these tags were introduced so that applications could query about relevant properties of other apps before sending them a message. For example, a control application like AppManager would first check the APPATTR_HasPrefsWindow tag for TRUE before sending an APPLIBMT_OpenPrefs message.
This is an interesting idea but something seems to be missing. APPATTR_CanCreateNewDocs and APPATTR_CanPrintDocs are there apparently in relation to the APPLIBMT_NewBlankDoc and APPLIBMT_PrintDoc messages, but there is no counterpart for the APPLIBMT_OpenDoc message.
So if this framework is to be consistent, there are two property tags missing:
REGAPP_CanOpenDocs
APPATTR_CanOpenDocs
Application Library app properties tags: something missing?
The Rear Window blog
