Amiga DOS scripts .def and second Keyword
Amigo1
Post by Amigo1 »
could someone please try this script.
The second Keyword (File2) is not read from the CLI and .DEF does not what it should.
What am I doing wrong?
.KEY FILE1/A, FILE2
.BRA {
.KET }
.DEF FILE2 "SomeTestString"
ECHO "{FILE1} is file 1 and {FILE2} is standard for File 2"
QUIT
the results are the following here:
7.AmigaOS:> execute ram:test-script RAM:
RAM: is File 1 and is standard for File 2
it should be
RAM: is File 1 and SomeTestString is standard for File 2
7.AmigaOS:> execute ram:test-script RAM: Data:
and here it should be
RAM: is File 1 and Data: is standard for File 2
On the other hand this works partially
.KEY FILE1/A, FILE2
.BRA {
.KET }
ECHO "{FILE1} is file 1 and {FILE2$Blabla} is standard for File 2"
QUIT
while if inserting a third argument like this
.KEY FILE1/A, FILE2, FILE3
.BRA {
.KET }
ECHO "{FILE1} is file 1 and {FILE2} is standard for File 2, while {FILE3$blablabla}"
QUIT
I get the following error:
EXECUTE: Parameters unsuitable for key "FILE1/A,".
joerg
Re: Amiga DOS scripts .def and second Keyword
Post by joerg »
Amigo1 wrote:could someone please try this script.
Remove the space(s) in .KEY, for the first example use ".KEY FILE1/A,FILE2", for the last one ".KEY FILE1/A,FILE2,FILE3".
ssolie
Post by ssolie »
Amigo1 wrote:What am I doing wrong?
The .KEY dot command is documented here:
http://wiki.amigaos.net/index.php/Amiga ... t_Commands
Amigo1
Post by Amigo1 »
Ok, thank you that slipped my view.. But .DEF still does not work. It doesn't pass the default value..
Amigo1
Post by Amigo1 »
I didn't see the space, in fact instead of consulting the online documentation, I read the old 3.1 AmigaDOS manual which doesn't mention not to use spaces.
Still the .DEF command does not work here it does not pass the default value.. :-(
ssolie
Post by ssolie »
Amigo1 wrote:...I read the old 3.1 AmigaDOS manual which doesn't mention not to use spaces.
The wiki should contain the newest and most up to date information available. You can even produce a paper manual from the wiki using the print/export features and have it professionally bound.
Be sure to review the .DEF documentation here:
http://wiki.amigaos.net/index.php/Amiga ... s#Defaults
Amigo1 wrote:
ssolie wrote:The .KEY dot command is documented here:
AFAIK that's a ReadArgs bug/feature, although it doesn't seem to be mentioned in the ReadArgs AutoDoc either.
gazelle
Post by gazelle »
Amigo1 wrote:Ok, thank you that slipped my view.. But .DEF still does not work. It doesn't pass the default value..
It does for me:
.KEY FILE1/A,FILE2
.BRA {
.KET }
ECHO "FILE1 = *"{FILE1}*" and FILE2 = *"{FILE2}*""
QUIT
7.RAM Disk:> Execute test ram:
FILE1 = "ram:" and FILE2 = "SomeTestString"
7.RAM Disk:> Execute test ram: test
FILE1 = "ram:" and FILE2 = "test"
7.RAM Disk:>
Amigo1
Post by Amigo1 »
It does for me:
.KEY FILE1/A,FILE2
.BRA {
.KET }
QUIT
7.RAM Disk:>
Well, I don't know what to tell, but today it works.I typed in your test script and it did what it should. I tried the unmodified script I wrote yesterday and it works too.
AFAIR I did some soft and hard reboots yesterday because of some quirks, and tried it after the reboot too. So I really don't know why it wasn't working.
This really drives me crazy.
Is there anything I can do to catch such a situation to pass it to you guys and improve the system?
I'll check the RAM of the A1..
@ssolie
Thank you both for taking the time to answer.
ssolie
Post by ssolie »
Amigo1 wrote:Is there anything I can do to catch such a situation to pass it to you guys and improve the system?
There is no bug here that I can see. Perhaps you have some suggestions to help improve the documentation on the wiki?
