Query function for hardware support of CompositeTags()
whose
Post by whose »
Hi!
I did some tests with CompositeTags(), and it´s a very nice feature. But I´m missing some method or function to query the driver´s/hardware´s capabilities regarding compositing. It´s a bit nasty to test with COMPFLAG_HardwareOnly for all BitMap format combinations possible, if there´s hardware support.
Btw., would it be possible to modify CompositeTags()´s vertex mode to accept negative coordinates incl. scissoring of those? Would make 2D gfx (scrolling) much more easy ;-)
Re: Query function for hardware support of CompositeTags()
Btw., would it be possible to modify CompositeTags()?s vertex mode to accept negative coordinates incl. scissoring of those? Would make 2D gfx (scrolling) much more easy
I think it does? My compositing based rotation and move previews in the next version of SketchBlock render to triangles with negative coords and they are simply clipped to the edges of the bitmap (or section of bitmap you have decided to render to).
whose
Post by whose »
Oh, ok... I should test again.
Edit: Works... don´t know what I´ve done wrong last time :? Ok, so please forget the 2nd part of my proposal :mrgreen:
