USB3
tommysammy
USB3
Post by tommysammy »
Does Ubuntu 12.04 LTS with the Kernel 3.14 RC4 support USB3?
Which card do i need?
I want to use this card for my 1TB USB3 HD(USB2 works too)
It is important for me that this usb card works under OS4.1 too but only in USB2 modus
danbeaver
Re: USB3
Post by danbeaver »
The official answer given a few months back was, "Not yet."
Re: USB3
tommysammy wrote:Does Ubuntu 12.04 LTS with the Kernel 3.14 RC4 support USB3?
Zappa2009 wanted USB3 support. And we have USB3 support since kernel vmlinux-3.8.7x1000-usb3-nouveau.tar.gz. :-) It means all new kernels have USB3 support.
Could you ask Zappa2009, which USB3 card did he buy, last year?
USB3 part of the kernel config:
CONFIG_USB_XHCI_HCD=y
tommysammy
Re: USB3
Ok i will ask him
zappa2009
Re: USB3
Post by zappa2009 »
Look here: http://forum.hyperion-entertainment.biz ... 204#p18204
Unter Linux works this Card fine but in OS4.1.6 no Driver are loaded.
USB3-Sticks , USB3-HDD (without additional Power) , USB3-SDXC-Reader , USB3-Cardreader works fine.
I can use the one USB3-Frontslot and 2 on the Card.
So we must wait for a USB3-Driver for OS4.1.6
And its a PCIe x1 Card so I dont know if a USB3-PCI will works with OS4.1.6.
tommysammy
Re: USB3
I bought me this USB3 card with front panel
I will report , how it works
http://www.ebay.de/itm/370852442310?ssP ... 1497.l2649
zappa2009
Re: USB3
Post by zappa2009 »
Looks like the same as mine. Only the Color is different.
Tell us how your Card can work with OS4.1.6 :mrgreen:
danbeaver
Re: USB3
Post by danbeaver »
I ordered this one based on the NEC D720201 chipset and connected it to my 2 front USB 3.0 ports. It works perfectly in Ubuntu 12.04 although I have not done any speed tests.
http://www.ebay.com/itm/290992682004?ss ... 1439.l2649
And the price was right.
tommysammy
Re: USB3
How must i activate USB3 ? I have now a PCI-E USB3 card installed
danbeaver
Re: USB3
Post by danbeaver »
tommysammy wrote:How must i activate USB3 ? I have now a PCI-E USB3 card installed
I just plugged in the card and booted Ubuntu.
