[ANSWER = "No"] Share CHOOSER_Labels list?
gazelle
Post by gazelle »
Is it allowed to share a labellist for choosers? I didn't find anything in the docs. It works so far.
There also seems to be a bug with freeing the allocated nodes. According to the autodocs, the nodes should be freed on disposal.
CHOOSER_Labels (struct List *)
List of labels. Each node must be allocated with the AllocChooserNodeA() function. The list will be freed automatically when the object is disposed of.
But when I do (after DisposeObject() ):
while ( (node = IExec->RemHead(list)) )
	IChooser->FreeChooserNode(node);
I get the full list of nodes and no memguard hit for freeing something twice.
salass00
Re: Share CHOOSER_Labels list?
Post by salass00 »
That must be a mistake in the autodoc because the labels list is only freed automatically on DisposeObject() if it was created by the chooser class, that is if you used CHOOSER_LabelArray instead of CHOOSER_Labels.
I just fixed it in the SVN.
gazelle
Post by gazelle »
Ok, thanks.
What about the real question to share the list for different choosers?
salass00
Post by salass00 »
gazelle wrote:Ok, thanks.
Well sharing the list shouldn't be a problem with the current chooser.gadget code at least.
gazelle
Re: [ANSWERED] Share CHOOSER_Labels list?
Post by gazelle »
Thanks again. I can confirm that it works, no reaper so far (and I'm doing it since some days).
ssolie
Post by ssolie »
gazelle wrote:Thanks again. I can confirm that it works, no reaper so far (and I'm doing it since some days).
Objects (lists, etc.) that you pass control over to a BOOPSI object should never be shared unless explicitly written otherwise. You are just asking for trouble.
gazelle
Post by gazelle »
ssolie wrote:Objects (lists, etc.) that you pass control over to a BOOPSI object should never be shared unless explicitly written otherwise. You are just asking for trouble.
That's what I feared, but it worked so well. Ok, time to restructure my code than.
