SOLVED: Ubuntu 12.04 LTS : kernel boot problem
Post by zzd10h »
Hello,
I have installed the 12.04 LTS yesterday evening with the kernel 3.10.15 on a CF without problem.
I have only 1 harddrive with both AmigaOS and LinuxPPC (I have replaced MintPPC by Ubuntu 12.04 LTS)
Boot from HD was OK until this morning.
This morning I installed the 256 Ubuntu updates and now I'm unable to boot on my Linux partition.
Here are my CFE settings
bootargs=root=/dev/sda4
MENU_2_LABEL=Ubuntu 12.04 LTS
MENU_2_COMMAND=boot -elf -noints -fatfs cf0:vmlinux-3.10.15
First, I had CFE error messages
"ran off of fat chain !"
"fat entries should be > -2"
I thought that I corrupted the kernel files on my CF therefore I redownloaded them.
And now, I have "not a elf file" when I try to boot on "cf0:vmlinux-3.10.15" or "cf0:vmlinux-3.10.15-ubuntu" or even on the unstable "cf0:vmlinux-3.12"
Of course all these files are in the root of my CF0:
Is somebody know if it could be the updates who kills my Linux setup ?
Thank you for help.
Guillaume
gazelle
Re: Ubuntu 12.04 LTS : kernel boot problem
Post by gazelle »
You are using the wrong filesystem (maybe FAT32 instead od FAT16) on your cf card.
Post by zzd10h »
Thank you Gazelle but it's well in FAT.
I didn't reformat my CF and it worked for months (with MintPPC) and yesterday (with Ubuntu LTS)...
gazelle
Post by gazelle »
But you did copy something onto the cf card?
I had the same with my usb-stick. It worked well but suddenly it stopped working after I copied a new kernel onto it. This must have triggerd something cfe didn't like. After reformating the stick with FAT16 it started working again.
Post by zzd10h »
Right Gazelle, I copied some files on it before it fails.
I just reformated my CF and now it works !
Thank you very much.
