Find_53.13 unable to find the very last word
AlexBene
Post by AlexBene »
Find 53.13 (24/11/12)
Report_2014.02.17.0002_Find_53.13
By: Alexander Benedictov
alexbene@mail.ru
Find 53.13 cannot find the very last word in a file
Search 52.1 (09/12/06) does find that word in a file.
For example, please copy this file to RAM:T and
try to find that file by the very last word using
Find and Search.
Abracadabra
Re: Find_53.13 unable to find the very last word
It works here, using my public (non-beta) installation with the same versions as yours:
$ echo >T:Testfile "This is a test of finding the last word."
$ echo >>T:Testfile "The last word in the last line."
$ search T: line quick
RAM Disk:T/Testfile
     2 The last word in the last line.
$ find T: contents line
Testfile                        73 ----rwed 18/02-2014 23:07:09 T:
$ search T: line. quick
RAM Disk:T/Testfile
$ find T: contents line.
$ version `which search` file full
Search 52.1 (09/12-2006)
$ version `which find` file full
Find 53.13 (24/11-2012)
As you can see, I even tried searching both with and without the final full stop.
In all cases, the file is found.
Anything I have overlooked that we are doing differently?
It may be that the last line in the file (or the only line) is not terminated with a NL. I have noticed some applications like NotePad (and its derivatives) can not find a string on the last line unless the last line has a NL character.
Bingo - that's it!
I just repeated the above test, but with an added NOLINE on the second echo statement.
This showed the issue perfectly; Seach could find the file, but Find couldn't.
I have now made a BZ entry for this.
Thanks for reporting, AlexBene! (And Tony for the hint ;-)).
