Reaction: Required classes
gazelle
Post by gazelle »
Do I need to open required classes of a class I want to use by myself?
Example:
The "clicktab.gadget" autodocs mentions "REQUIRES chooser.gadget". Do I have to open the "chooser.gadget" myself or will this be handled internally by the "clicktab.gadget"? The docs are not clear in that (or i didn't find it).
trixie
Re: Reaction: Required classes
Post by trixie »
Normally, all dependencies are handled internally unless the particular class is badly written. "REQUIRES" means that the respective dependency must be present in the system.
The Rear Window blog
gazelle
Post by gazelle »
trixie wrote:Normally, all dependencies are handled internally [...]
Ok, thanks. I was hoping for that answer because I'm about to use the "getcolor.gadget" which does have a long required list.
