Usb MassStorages in Prefs
tommysammy
Post by tommysammy »
I wish the USB Mass Storages for Prefs.
It makes user life easier. I don`t like it to use keyboard shortcuts which can no one remember.It is my opinion it belongs with a pretty icon in Prefs.
Yes i can use scripts or other things for the same result but AmigaOS should be user friendly.We also have users who do not understand something like to use scripts etc.
Thing about it
gazelle
Re: Usb MassStorages in Prefs
Post by gazelle »
It's a commodity and you can make the display visible via Exchange.
SOFISTISOFTWARE
Post by SOFISTISOFTWARE »
gazelle wrote:It's a commodity and you can make the display visible via Exchange.
i've a problem with masstorage prefs, when i playing mp3 music from my external usb HD ntfs with AmigaAMP and i recall the prefs with ctrl+alt+m often it freeze the system, sometime when you open it, sometime when you close it
Last edited by SOFISTISOFTWARE on Sat Feb 15, 2014 9:35 am, edited 1 time in total.
Sam 460EX, 2Gb Ram, Radeon R7 250E, OS4.1 FE
tommysammy
Then it should at least be there with an icon
Due to the way it works (created in-memory when USB massstorage is loaded), I don't think that's feasible.
However, what it could do is add itself to the WB Tools menu.
