I did buy an optical mouse & Gigabyte keyboarI.
On my SAM 460ex booting with the optical USB dongle plugged in invariably bring the CLI window up after having opened the AOS4.1 log screen.
I don't seem the only one having these problems: there was a thread about this on Amigans website.
What can i do or hope for?
Optical mouse& keyboard problems
- javierdlr
Re: Optical mouse& keyboard problems
HiJosDuchIt wrote:I did buy an optical mouse & Gigabyte keyboarI.
Does it happens ALWAYS?
Try disabling USB ohci module (comment out in Kicklayout) if not already done, letting only USB uhci & ehci modules load/start.
With update5, update6? Maybe trying to rvert to a prevous USBxxxxx kicklayout files solves it. If you can, try with Update5.
When you get on the system CLI try to see what DumpDebugBuffer tool outputs or post it here if you can.
@javier
It does not happen always
Pracically always after some crash or freeze (whether you reboot warmor cold)
Rarely when you just reboot Ctl Amiga Amiga
I commented out ohci, and maybe there is some progresbut not much The problem is certainly not gone
Dumpdebugbudffer output when the CLI showed up is below.(ohcicomented out)
Please note this too:
withou uncommenting i could not boot when an USB stick was pluggd in: the USB stick reading out never stopped.
Now i can boot in some cases but the same problem reappears in other cases, durring "scanning for USB storage devices" boot phase.
w
Can you explain which files exactly?Maybe trying to rvert to a prevous USBxxxxx kicklayout files solves it. If you can, try with Update5.
w
Hidden Text - Click to Show :
- javierdlr
So, when you cold boot (reset button) sometimes Uboot says/shows only 'USB devices: 1' plugged.It does not happen always
Here happens too sometimes when system has a hard crash/freeze, upon reseting my SAM460ex I only get 'USB devices: 1', have to power off and power on machine and it shows again USB devices: 5'
If you use AmiUpdate you can rollback USB, but forget what I said, maybe is causes too much trouble mixing old/new usb libs/modules.I commented out ohci, and maybe there is some progresbut not much The problem is certainly not gone
IIRC it was massstorage problem (solved on latest update).withou uncommenting i could not boot when an USB stick was pluggd in: the USB stick reading out never stopped.
