MUI 4.0 (20.368) bug: Wrong position of text
Locked
samo79
Post by samo79 »
I posted this into the official bugtracker aswell, but currently it is in awaiting for moderation so while i wait ..
Since latest version of MUI4 the text into the statusbar of Odyssey will be placed at the wrong position by default, such text will be displayed at the center of the statusbar rathen then at the left as it was before (and as it should be)
See the text "Pronto" in OWB statusbar
http://s28.postimg.org/m3if0p9xp/statusbar.png
sundown
Re: MUI 4.0 (20.368) bug: Wrong position of text
Post by sundown »
Text in wookies text buttons are shifted to the right now. Also some app MUI settings won't save right for me, changes "stick" till I quit & are gone when I restart the MUI app. Something funny going on with ENV:, so can't tell if its an os4 or MUI problem.
kas1e
Post by kas1e »
@Samo
Thore fixed it already (check your ticket)
tboeckel
Post by tboeckel »
sundown wrote:Text in wookies text buttons are shifted to the right now.
If BZ #8700 was raised by you then I am still waiting for a reply from your side. If BZ #8700 was not raised by you then you can provide the requested screenshots nevertheless, too. I tried WookieChat myself and for me all buttons look correct.
sundown wrote:Also some app MUI settings won't save right for me, changes "stick" till I quit & are gone when I restart the MUI app. Something funny going on with ENV:, so can't tell if its an os4 or MUI problem.
As Roman already pointed out this has been fixed already. It was a bug that was overseen when porting the keyfile mechanism back from MUI 3.9.
Further bugs should not be discussed here, but in the bugtracker at http://muidev.de.
Locked
