Strange error output using SystemTags()
javierdlr
Post by javierdlr »
Hi using in DateTime.docky to launch an external program (SYS:Prefs/Time) when I click on Time prefs USE|SAVE I get a requester 'Could not open input file "ENV:Sys/time.prefs".' the launch form I'm using is:
int32 beginCommand(char *command)
 BPTR file;
 if( (file = IDOS->Open("CON:0/40/640/150/DateTime.docky/AUTO", MODE_OLDFILE)) )
  return IDOS->SystemTags(command,
                          SYS_Input,        file,
                          SYS_Output,     0,
                          SYS_Asynch,     TRUE,
                          SYS_UserShell, TRUE,
                         TAG_END);
 return(RETURN_ERROR);
Changed to use (Guillame Boesel uses this way on his dockies), but get the same requester:
IDOS->SystemTags("SYS:Prefs/Time", SYS_Input,NULL, SYS_Output,NULL,
                                SYS_Error,NULL, SYS_Asynch,TRUE, TAG_END);
Any ideas why I get such requester?
TIA
colinw
Re: Strange error output using SystemTags()
Post by colinw »
javierdlr wrote:Hi using in DateTime.docky to launch an external program (SYS:Prefs/Time)
TIA
Is it a requester, or a text message in the console window you opened. ?
And, is there actually a file at; "ENV:Sys/time.prefs" ?
javierdlr
Post by javierdlr »
TIA
-Is a requester, 'Preferences' (MSG_IP_REQTITLE) as window title.
-Yep, I have such file in ENV/ENVARC
-Tried with public OS4.1 update6 and i don't get such strange requester. Will try to find what happens.
EDIT: looking with Snoopy I can see that with public OS4.1 upd6:
00603 : Time            : o.k. = Open("Time.info",OLD) = [0x18C42F42] [84uS]
00604 : Time            :        CurrentDir("SYS:")
00605 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x60B1BEA0,0x00000000) = 0 [40uS]
00606 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x60B1BB20,0x00000000) = 0 [15uS]
00607 : Time            : o.k. = [exec] OpenDevice("timer.device",0,0x60B5ED80,0x00000000) = 0 [45uS]
00608 : Time            : o.k. = Open("ENV:Sys/time.prefs",NEW) = [0x18C42F42] [145uS]
00609 : « IPrefs »      : o.k. = Lock("ENV:Sys/time.prefs",SHARED) [142uS]
00610 : « IPrefs »      : o.k. = Examine("time.prefs") [155uS]
00611 : Time            : o.k. = SetProtection("Env:Sys/time.prefs",0x00000002) [284uS]
00612 : Time            : o.k. = [exec] FindPort("Time ClockPort") [13uS]
And on my beta partition (see 00143 FAIL):
00137 : Time            : o.k. = Open("Time.info",OLD) = [0x177C28CE] [93uS]
00138 : Time            :        CurrentDir("SYS:")
00139 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x59F42EA0,0x00000000) = 0 [35uS]
00140 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x59F42B20,0x00000000) = 0 [14uS]
00141 : Time            : o.k. = [exec] OpenDevice("timer.device",0,0x59F74D80,0x00000000) = 0 [44uS]
00142 : Time            : o.k. = Open("ENV:Sys/time.prefs",NEW) = [0x177C28CE] [152uS]
00143 : « IPrefs »      : FAIL = Lock("ENV:Sys/time.prefs",SHARED) [86uS]
00144 : « IPrefs »      : o.k. = [exec] OpenLibrary("iffparse.library",39) [20uS]
00145 : « IPrefs »      : FAIL = Open("ENV:Sys/time.prefs",OLD) = [0x00000000] [74uS]
00146 : « IPrefs »      : o.k. = [exec] OpenLibrary("requester.class",50) [39uS]
00147 : Time            : o.k. = SetProtection("ENV:Sys/time.prefs",0x00000002) [950uS]
TIA
javierdlr
Re: Strange error output using SystemTags() [SOLVED?]
Post by javierdlr »
My again. SOLVED!!!
If AmiDock icon has a NEGATIVE priority I get such problem!!!! (I had it to -10 [CX_PRIORITY=-10]) so it was launched the last one from WBStartup)
Tested with -10 and -1 ->problem!!! Requester shows up.
Tested with 0 and 1 ->no requester
Has enyone an explanation for such strange thing?
colinw
Post by colinw »
javierdlr wrote:Has enyone an explanation for such strange thing?
Looking at your log, I can see a possible race problem which the priority change could affect.
You will notice that line 142 Open()'s the file in "NEW" mode, which implies an EXCLUSIVE_LOCK,
but immediately afterwards on line 143 a SHARED_LOCK is attempted on the same file.
If the EXCLUSIVE_LOCK was not released before the SHARED_LOCK was attempted,
the SHARED_LOCK call will fail.
If you enabled UnLock() and Close() function logging, you will probably see that an asynchronous
process access caused a race condition where the Close() for the 'new' file hadn't finished before
the Lock() on line 143 was attempted.
By the way, your code is also faulty. It is possible for SystemTags() to fail with a returncode of -1
and if it does, your "file" stream never gets closed and is left orphaned forever.
javierdlr
Post by javierdlr »
Ok thx for explanation, setting AmiDock priority to -1 I get such snoopy log (enabling Close() function):
00139 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x52FECEA0,0x00000000) = 0 [35uS]
00140 : Time_Clock      : o.k. = [exec] OpenDevice("timer.device",0,0x52FECB20,0x00000000) = 0 [15uS]
00141 : Time            : o.k. = [exec] OpenDevice("timer.device",0,0x53008D80,0x00000000) = 0 [44uS]
00142 : Time            : o.k. = Open("ENV:Sys/time.prefs",NEW) = [0x17B94CDC] [148uS]
00143 : « IPrefs »      : FAIL = Lock("ENV:Sys/time.prefs",SHARED) [67uS]
00144 : « IPrefs »      : o.k. = [exec] OpenLibrary("iffparse.library",39) [17uS]
00145 : « IPrefs »      : FAIL = Open("ENV:Sys/time.prefs",OLD) = [0x00000000] [62uS]
00146 : « IPrefs »      : o.k. = [exec] OpenLibrary("requester.class",50) [40uS]
00147 : « IPrefs »      : o.k. = Lock("SYS:Prefs/Presets/Requester",SHARED) [122uS]
00148 : « IPrefs »      :        CurrentDir("SYS:Prefs/Presets/Requester")
00149 : « IPrefs »      : o.k. = [exec] OpenLibrary("datatypes.library",44) [18uS]
00150 : « IPrefs »      : o.k. = [exec] OpenLibrary("dos.library",0) [6uS]
00151 : « IPrefs »      : o.k. = Lock("Error",SHARED) [37uS]
00152 : « IPrefs »      : o.k. = [exec] OpenLibrary("datatypes.library",44) [10uS]
00153 : « IPrefs »      : FAIL = [exec] OpenResource("PicassoIV.resource") [8uS]
00154 : « IPrefs »      :        CurrentDir("<ZERO>")
00155 : Time            : o.k. = Close("ENV:Sys/time.prefs") [30402uS]
00156 : Time            : o.k. = SetProtection("ENV:Sys/time.prefs",0x00000002) [385uS]
00157 : Time            : o.k. = [exec] FindPort("Time ClockPort") [17uS]
00158 : Time_Clock      : o.k. = [exec] FindPort("Time Port") [6uS]
And I see Close() now :-)
Setting Time prefs icon priority to -1 I get the same requester.
So it's Time prefs sideeffect (bug?) for setting/"passing" a negative value to Time prefs priority?
Changed my launch command function to Guillaime Bosel "mode":
 return IDOS->SystemTags(command, SYS_Input,NULL, SYS_Output,NULL,
salass00
Post by salass00 »
@javierdir
Add "NP_Priority, 0," to the SystemTags() tags and Time prefs will always be started with priority 0 no matter what AmiDock is set to.
javierdlr
Post by javierdlr »
salass00 wrote:@javierdir
THX for the tip. Now works fine even AmiDock has Pri. -1 :-)
BTW: Should I fill a BZ entry about Time prefs and setting its icon Pri. -1 getting such "strange" requester?
Looking at the log it's likely not Time Prefs that is opening the requester but IPrefs. It's likely waiting on a notification of the change to ENV:sys/time.prefs and attempting to read the changed contents. Because you were running Time prefs with a low priority IPrefs attempts to read the file before you have finished saving to it.
In StartNotify it says "For files, you will be notified after the file is closed." So this seems a bit odd. Unless it's using NotifyVar() in which I dodn't know how that works.
colinw
Post by colinw »
NotifyVar() works simply by adding hook structure nodes to a list.
When an environmental function is called that modifies a variable, like SetVar() or DeleteVar(),
the variable with the matching name has it's hook function called, and you do what you need to in there.
That's it, nice and simple and very fast, low overhead and no filesystem calls required.
Unfortunately, IPrefs still uses the filesystem style file notifications on its prefs files, and that's where
the asyncronous priority collision is likely occuring, when it gets a notification, it performs various
filesystem operations to implement the prefs change, unfortunately, the filesystem style notification
handler runs asyncronously at priority 9 or 10, and the IPrefs asyncronous handler process runs at priority 0.
The side effect of using filesystem style notifications is that you can get multiple notifications for the
one "save" operation, in that multiple filesystem calls may be involved, for example Open()-Write()-Close()
will send one notification on the Close(), but if one were to also do a SetComment(), SetProtection(),
SetDate(), while the file was still open, you would get those three change events before the Close()
event for the Write() change.
As has been documented, we are moving away from using filesystem style notifications for anything
ENV: ENVARC: related, but in this case, the way the prefs files are being changed is not entirely
consistent yet, some are still not using the propper DOS environmental functions, SetVar(), etc...
which means they would miss out on a NotifyVar() notification if they were being modified with
the old Open()-Write()->Close() method.
This will be addressed as time permits and hopefilly all the prefs files will eventually be created or
modified with the DOS environmental functions, then the problems like this should just go away.
