Search ram: pattern t
JosDuchIt
Post by JosDuchIt »
.Amiga OS 4:> search ram: pattern t
Disk.info..
1 x.í...UE.Æß.³0À.f....DöÅîfS@...d.}G....Ý.%F@...5q.eQ.... .1@..4..Ì0#.L.ÿ.Æ.I..ú.ïë.ªßµ}¯[ÇIº./Í»·.ï;çTÕ©{/©Te©,.¥²T.ÊRY*Kéò
2 ã·lÙÒÝqÇ.®U«VîÎ;ït­[·vmÚ´qmÛ¶uíÚµsíÛ·/...:.tìØ±L¨n¦~è.q..q...ðñvZ:yòäúiÎ.Uª{´òØ1bÄ.×­[7W£F....çjÖ¬éjÕªåêÔ©ãêÖ
The same garbage every time.
Re: Search ram: pattern t
Post by thomasrapp »
You got what you've asked for. You told it to search every file in RAM: for the string "t" and it showed you that it found two lines in disk.info which contained "t".
JosDuchIt
Post by JosDuchIt »
OOops! Indeed, the list of "garbage" was much longer, and i did not notice the "disk.info" line, even after copying the 3 first lines.
