CFE settings for some Linux distributions
(276.87 KiB) Downloaded 284 times
MichaelMerkel
Re: CFE settings for some Linux distributions
Post by MichaelMerkel »
why posting a screenshot instead of the pure text? :shock:
that would other users enable to copy/paste what they want...
regards...
michael
Michael Merkel :lol:
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Thanks for posting this Christian.
If you want to easily produce a text file of your CFE settings, you can enter the following command in an Amiga Shell:-
nvgetvar >ram:cfe.txt
This will copy your CFE variables to the text file cfe.txt in RAM, which you can then post to the forum. (saves a lot of typing ;-))
Trevor
Edit: Note: it's always good to keep a copy of your normal cfe settings just in case, and this is the easiest way to save them. You can also read the settings in Ranger under the Firmware tab.
I'm just Breezin'
Thanks alot for your hint. :-)
Here you are:
name=options
little-endian?=
ETH0_HWADDR=00:50:C2:20:DA:9E
MENU_0_LABEL=AmigaOS
MENU_1_LABEL=AmigaOS CD Boot
MENU_0_COMMAND=setenv amigaboot_quiet Y ;boot -fs=amigafs ide0.0:amigaboot.of
MENU_1_COMMAND=setenv amigaboot_quiet Y ;boot -fs=iso atapi0.1:amigaboot.of
MENU_DEFAULT=0
os4_commandline=DEBUGLEVEL=0 SERIAL
speed=set pmu -astate=A4
MENU_TIMEOUT=6
MENU_4_LABEL=Lubuntu 12.04.3 LTS Kernel 3.9.8
MENU_4_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb1 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.9.8X1000
STARTUP=speed;menu
MENU_5_LABEL=Fedora 17 Kernel 3.10.3
MENU_5_COMMAND=set pmu -astate=A4 ; setenv bootargs "rd.md=0 rd.lvm=0 rd.dm=0 SYSFONT=True KEYTABLE=de rd.luks=0 root=/dev/sdb3 LANG=de_DE.UTF-8 ro rhgb quiet" ; boot -elf -noints -fatfs cf0:vmlinux-3.10.3-2-ubuntu
MENU_8_LABEL=Lubuntu 12.04.3 Kernel 3.10.15
MENU_8_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb1 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.10.15-ubuntu
MENU_9_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb6" ; boot -elf -noints -fatfs cf0:vmlinux-3.9.8.1-opensuse
MENU_9_LABEL=openSUSE 12.3 Kernel 3.9.8.1
MENU_2_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sda4" ; boot -elf -noints -fatfs cf0:vmlinux-3.11
MENU_2_LABEL=Debian Sid Kernel 3.11
MENU_7_LABEL=openSUSE 11.1 Kernel 3.9.8.1
MENU_7_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb5" ; boot -elf -noints -fatfs cf0:vmlinux-3.9.8.1-opensuse
MENU_6_LABEL=Ubuntu 10.04.4 LTS Kernel 3.10.15
MENU_6_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb4 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.10.15-ubuntu
MENU_3_LABEL=Lubuntu 14.04 LTS Kernel 3.13
MENU_3_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb7 radeon.dpm=0 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.13
framebuffer=800/600/8/0x90000000/832
BOOT_CONSOLE=pcconsole0
CFE_VERSION=PAS-2.0.30
CFE_BOARDNAME=NEMO
CFE_MEMORYSIZE=8192
amigaboot_quiet=Y
With SliTaz. ;-)
name=options
little-endian?=
MENU_DEFAULT=0
MENU_TIMEOUT=6
STARTUP=speed;menu
MENU_3_LABEL=Lubuntu 14.04 LTS Kernel 3.14
MENU_8_LABEL=Lubuntu 12.04.4 Kernel 3.13.6
MENU_8_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb1 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.13.6
MENU_3_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb7 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-3.14-rc8
MENU_4_LABEL=SliTaz Snapshot 23 Kernel 3.14
MENU_4_COMMAND=set pmu -astate=A4 ; ramdisk -z -addr=0x24000000 -fatfs cf0:slitaz23.gz ; boot -elf -noints -fatfs cf0:vmlinux-3.14
CFE_BOARDNAME=NEMO
CFE_MEMORYSIZE=8192
amigaboot_quiet=Y
New backup. ;-)
name=options
little-endian?=
MENU_DEFAULT=0
MENU_TIMEOUT=6
STARTUP=speed;menu
MENU_5_LABEL=Fedora 17 Kernel 3.13.9
MENU_5_COMMAND=set pmu -astate=A4 ; setenv bootargs "rd.md=0 rd.lvm=0 rd.dm=0 SYSFONT=True KEYTABLE=de rd.luks=0 root=/dev/sdb3 LANG=de_DE.UTF-8 ro rhgb quiet" ; boot -elf -noints -fatfs cf0:vmlinux-3.13.9
MENU_4_LABEL=SliTaz Snapshot 25 Kernel 3.13.14
MENU_4_COMMAND=set pmu -astate=A4 ; ramdisk -z -addr=0x24000000 -fatfs cf0:slitaz25.gz ; boot -elf -noints -fatfs cf0:vmlinux-3.13.14
MENU_9_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb6" ; boot -elf -noints -fatfs cf0:vmlinux-4.1
MENU_9_LABEL=openSUSE Tumbleweed Kernel 4.1
MENU_3_LABEL=ubuntu MATE 17.04 Kernel 4.9
MENU_3_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb7 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-4.9
MENU_6_LABEL=Fedora 25 PPC64 Kernel 4.9
MENU_6_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb4" ; boot -elf -noints -fatfs cf0:vmlinux-4.9
MENU_2_LABEL=Debian Sid Kernel 4.8
MENU_2_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sda4" ; boot -elf -noints -fatfs cf0:vmlinux-4.8
MENU_8_LABEL=ubuntu MATE 16.04.1 LTS Kernel 4.8
MENU_8_COMMAND=set pmu -astate=A4 ; setenv bootargs "root=/dev/sdb1 quiet ro splash" ; boot -elf -noints -fatfs cf0:vmlinux-4.8
CFE_BOARDNAME=NEMO
CFE_MEMORYSIZE=8192
amigaboot_quiet=Y
