Darren
Save partition priorities in early startup
- DarrenHD
It would be nice to be able to change and save partition priorities and boot flags in early startup. If you are constantly switching back and forth between partitions it would save lots of time for this small capability. Especially on classic where you have to go through multiple reboots and if you don't hold the mouse buttons down at the right time to get into the early startup you have to wait for the entire boot. Trust me, it would save lots of time
Darren
Darren
Re: Save partition priorities in early startup
On my A1200 I normally just use Media Toolbox from WB to change the boot priorities and then do a cold reboot. I never bother with the ESM.
But yes, it would be nice to have e.g. a command line program to set the boot priority of a volume and save the change to the RDB. That would save waiting for MT to load (which can take some time on an A1200
) and going through several windows and hitting several gadgets to achieve the same.
Nies
Nies
- thomasrapp
I made a simple boot partition selector with RequestChoice and ChangeBootPri. No need to run HDToolbox or Media Toolbox or similar.
http://thomas-rapp.homepage.t-online.de ... ootpri.lha
.key changebootpri
.def changebootpri programme:sources/changebootpri
set choice `requestchoice "Startauswahl" "*nBitte wählen Sie das gewünschte Startlaufwerk*n" "OS 3.9|WB 3.1|OS 4.0|MorphOS|Netboot|Abbruch"`
if $choice eq 0
skip quit
endif
if $choice eq 1 ; OS 3.9
<changebootpri> >nil: IDH0 1 ; OS 3.9
<changebootpri> >nil: IDH1 0 ; WB 3.1
<changebootpri> >nil: IDH2 0 ; OS 4.0
<changebootpri> >nil: IDH3 0 ; MorphOS
<changebootpri> >nil: IDH8 0 ; Netboot
set dev "IDH0 / OS 3.9"
skip done
endif
if $choice eq 2 ; WB 3.1
<changebootpri> >nil: IDH0 0 ; OS 3.9
<changebootpri> >nil: IDH1 1 ; WB 3.1
set dev "IDH1 / WB 3.1"
skip done
endif
if $choice eq 3 ; OS 4.0
<changebootpri> >nil: IDH2 1 ; OS 4.0
set dev "IDH2 / OS 4.0"
skip done
endif
if $choice eq 4 ; MorphOS
<changebootpri> >nil: IDH3 1 ; MorphOS
set dev "IDH3 / MorphOS"
skip done
endif
if $choice eq 5 ; Netboot
<changebootpri> >nil: IDH8 1 ; Netboot
set dev "IDH8 / Netboot"
skip done
endif
lab done
requestchoice >nil: "BootSelector" "Boot device set to $dev." "Ok"
lab quit
Splendid! Actually, I think I've read about this (or similar) sometime before.
Now I'll make the effort of getting it on my A1200 and put it to good use. Thanks!
- DarrenHD
Thank you very much I will try this outthomasrapp wrote:I made a simple boot partition selector with RequestChoice and ChangeBootPri. No need to run HDToolbox or Media Toolbox or similar.
.key changebootpri .def changebootpri programme:sources/changebootpri set choice `requestchoice "Startauswahl" "*nBitte wählen Sie das gewünschte Startlaufwerk*n" "OS 3.9|WB 3.1|OS 4.0|MorphOS|Netboot|Abbruch"` if $choice eq 0 skip quit endif if $choice eq 1 ; OS 3.9 <changebootpri> >nil: IDH0 1 ; OS 3.9 <changebootpri> >nil: IDH1 0 ; WB 3.1 <changebootpri> >nil: IDH2 0 ; OS 4.0 <changebootpri> >nil: IDH3 0 ; MorphOS <changebootpri> >nil: IDH8 0 ; Netboot set dev "IDH0 / OS 3.9" skip done endif if $choice eq 2 ; WB 3.1 <changebootpri> >nil: IDH0 0 ; OS 3.9 <changebootpri> >nil: IDH1 1 ; WB 3.1 <changebootpri> >nil: IDH2 0 ; OS 4.0 <changebootpri> >nil: IDH3 0 ; MorphOS <changebootpri> >nil: IDH8 0 ; Netboot set dev "IDH1 / WB 3.1" skip done endif if $choice eq 3 ; OS 4.0 <changebootpri> >nil: IDH0 0 ; OS 3.9 <changebootpri> >nil: IDH1 0 ; WB 3.1 <changebootpri> >nil: IDH2 1 ; OS 4.0 <changebootpri> >nil: IDH3 0 ; MorphOS <changebootpri> >nil: IDH8 0 ; Netboot set dev "IDH2 / OS 4.0" skip done endif if $choice eq 4 ; MorphOS <changebootpri> >nil: IDH0 0 ; OS 3.9 <changebootpri> >nil: IDH1 0 ; WB 3.1 <changebootpri> >nil: IDH2 0 ; OS 4.0 <changebootpri> >nil: IDH3 1 ; MorphOS <changebootpri> >nil: IDH8 0 ; Netboot set dev "IDH3 / MorphOS" skip done endif if $choice eq 5 ; Netboot <changebootpri> >nil: IDH0 0 ; OS 3.9 <changebootpri> >nil: IDH1 0 ; WB 3.1 <changebootpri> >nil: IDH2 0 ; OS 4.0 <changebootpri> >nil: IDH3 0 ; MorphOS <changebootpri> >nil: IDH8 1 ; Netboot set dev "IDH8 / Netboot" skip done endif lab done requestchoice >nil: "BootSelector" "Boot device set to $dev." "Ok" lab quit
Darren
- DarrenHD
DarrenHD wrote:Thank you very much I will try this outthomasrapp wrote:I made a simple boot partition selector with RequestChoice and ChangeBootPri. No need to run HDToolbox or Media Toolbox or similar.
Darren
Just wanted to report back this is working perfectly on my system...Thanks again Thomas!
Darren
I ended up just installing the ChangeBootPri command and type what I need each time I need it. I could have amended the script to my setup, and I'm sure it would have worked fine, but I haven't bothered so far
Anyway, the command works fine here as well. Thanks!
Betst regards,
Betst regards,
- DarrenHD
I'd like to make an icon out of it...I assume you could do this with IconX ?nbache wrote:I ended up just installing the ChangeBootPri command and type what I need each time I need it. I could have amended the script to my setup, and I'm sure it would have worked fine, but I haven't bothered so far
Betst regards,
IconX can do it, yes, or you could simply make a tool icon and set it to run from Shell.
Are you calling this script from the startup-sequence of each partition or have you created a very small partition for this?
