Pegasos2 Tips & Tricks
This forum is for Pegasos II specific issues.
tlosmx
Post by tlosmx »
Hi there i open this tread for discussion about optimizing the Amiga Os 4.1 on Pegaos2 system.
Like how to make faster the hd, or install an ssd on Peggy better buffers ... Graphic lan and improvement with rams.
I think about this because all us information can be used for the Wiki page of AmigaOs 4.1
share your tips i will share mine
First of my tip is : using an SSD with a Sata to Ata controller.
I found one really cheap on ebay only 2.50 euro
http://www.ebay.it/itm/ADATTATORE-CONVE ... 289&_uhb=1
and it is working great ,my SSD is a Samsung 840 Sata 3 i put a buffer of 800 for have a better performances
ssolie
Re: Pegasos2 Tips & Tricks
Post by ssolie »
tlosmx
Post by tlosmx »
Best 2Gb memory configuration:
I checked many ram company for add 2gb full system bosted on pegasos but the best result i had with
2x1Gb Crucial pc3200 system run perfect stable and full 2gb bosted!
1x1GB Kingstone pc3200 and 1x1Gb Buffalo pc3200 ... (kingostone in the first slot near the cpu the other in other slot)... system perfect working and it is stable.
Soon i will post exactly the serial of all the rambank
Serials of the rambank:
Crucial: PC3200U - 30331Z 1GB DDR 400 CL3 not ECC unbuffered (perfect woking with 2x modules)
Buffalo: PC3200U -30330-B1 1GB DDR 4000 CL3 Not ECC unbuffered (working great in second slot in couple with kingstone 3200 1GBDDR 400)
Kingstone: sorry i dont have the stick on it for know the serial
sailorMH
Post by sailorMH »
many thanx for info. I made several experiments with 2GB on PegasosII but without success. I still have 1GB only..
smf
Post by smf »
sailorMH wrote:many thanx for info. I made several experiments with 2GB on PegasosII but without success. I still have 1GB only..
You probably have a "bad" motherboard revision then.
The first Pegasos2 i bought many years ago didn't work with 2gb, later on i bought another motherboard with a broken cpu card very cheap and that motherboard handles 2gb memory very well with the same memory modules that didn't work in the other machine.
tlosmx
Post by tlosmx »
Wath motherboard revision do you have ?
there is the last openfirmaware on it?
note: i add the serial of the ram banks in the tread
sailorMH
Post by sailorMH »
I have motherboard: 2b2
Smart firmware 1.2 ( 20040810112413)
fimware was upgraded due to 1G ethernet working
tlosmx
Post by tlosmx »
i know the r3 start having less problems with Memory..the r5 is the top for 2 gb of ram
sailorMH
Post by sailorMH »
OK, but what firmware revision is newest for my motherboard 2b2?
on this old thread
http://www.powerdeveloper.org/forums/vi ... php?t=1761
they are said, that my actual revision is last for 2b1..
and here http://en.wikipedia.org/wiki/Pegasos is also not very clear..
do you have some idea where obtain last firmware for 2b2?
thx
tlosmx
Post by tlosmx »
Turn On your pegasos and press esc for not make the machine auto boot and load the os.
There you can see the Openfirmware revison and compare with Wikipedia site .
About download i dont know how to help you because bplan site only show a file to download and i think is only for i think the B2R5
http://www.bplan-gmbh.de/flash-update-f ... sos-2.html <-- here but not try to install or you can broke your machine
