Wide 'W'
djg
Wide 'W'
Post by djg »
I may have found a small bug. When I open a non proportional font like DejaVu Sans and write to a window right next to the left border using IGraphics->Text(rp, Window->BorderLeft, y), and the first character is a 'W', a column of one pixel wide is cleared from the left border.
Am I write or wrong?
Re: Wide 'W'
I seem to remember from years ago that some Locales (and fonts) do that. I can't offer you a fix.
If you could provide a code example, (and all your system settings), we can test it and write a report for you.
djg
Re: Wide 'W'
Post by djg »
tonyw wrote:I seem to remember from years ago that some Locales (and fonts) do that. I can't offer you a fix.
I guess I will have to work around this then by writing at least one pixel to the right.
I don't know how to gather all my system settings, but I've tried it on a fresh install of Update 1 on a new partition, and it happened there too.
My computer is a SAM440ep, and the screenmode is Radeon M9:1024x768 ARGB for Update 1 or RADEON M9:1920x1080 RGB16 for Update 6,
although I don't think that matters.
It looks like this:
Font Test Window
Font Test Window
Below is my code:
;/* FontTest
gcc -o FontTest FontTest.c -Wall -Werror -lauto
quit
#include <intuition/intuition.h>
#include <proto/exec.h>
#include <proto/intuition.h>
#include <proto/graphics.h>
#include <proto/diskfont.h>
#include "stdio.h"	/*  for printf()  */
#include "stdlib.h"	/*  for exit()  */
#include "string.h"	/*  for strlen()  */
struct Window *Window = NULL;
struct TextFont *TextFont = NULL;
void CloseAll(void)
    if (TextFont) IGraphics->CloseFont(TextFont);
    if (Window) IIntuition->CloseWindow(Window);
void Fail(char *failString)
    printf("%s\n", failString);
    CloseAll();
    exit(FALSE);
void OpenAll(void)
    static char WindowTitle[] = "Font Test";
    struct TextAttr textAttr = { "DejaVu Sans.font", 16, 0, 0 };
    if (!(TextFont = IDiskfont->OpenDiskFont(&textAttr)))
        Fail("could not open font");
    if (!(Window = IIntuition->OpenWindowTags(NULL,
                       WA_Title, WindowTitle,
                       WA_Width, 200,
                       WA_Height, 100,
                       WA_Flags, WFLG_CLOSEGADGET | WFLG_DRAGBAR | WFLG_DEPTHGADGET,
                       WA_IDCMP, IDCMP_ACTIVEWINDOW | IDCMP_INACTIVEWINDOW | IDCMP_CLOSEWINDOW)))
        Fail("could not open window");
void FontTest(void)
    char testString[] = "Write Test";
    struct RastPort *rp = Window->RPort;
    IGraphics->SetFont(rp, TextFont);
    IGraphics->SetAPen(rp, 1);
    IGraphics->Move(rp, Window->BorderLeft, Window->BorderTop + rp->TxBaseline);
    IGraphics->Text(rp, testString, strlen(testString));
int main(void)
    BOOL done;
    struct IntuiMessage *imsg;
    OpenAll();
    FontTest();
    done = FALSE;
    while (!done)
        imsg = (struct IntuiMessage *) IExec->GetMsg(Window->UserPort);
        if (!imsg)
            IExec->Wait(1 << Window->UserPort->mp_SigBit);
            continue;
        if (imsg)
            switch (imsg->Class)
                case IDCMP_CLOSEWINDOW:
                    done = TRUE;
                    break;
                case IDCMP_ACTIVEWINDOW:
                case IDCMP_INACTIVEWINDOW:
                    FontTest();
                    break;
            IExec->ReplyMsg((struct Message *) imsg);
    CloseAll();
    return 0;
Re: Wide 'W'
Post by thomasrapp »
May be a problem with the font. The same happens on OS 3.9 with ttf.library and DejaVuSans.ttf from dejavu-fonts.org.
gazelle
Re: Wide 'W'
Post by gazelle »
Maybe because of a negative kerning of the "W".
You could check with the TextExtent:
void FontTest(void)
    struct TextExtent te;
    WORD x, y;
    x = Window->BorderLeft;
    y = Window->BorderTop + rp->TxBaseline;
    IGraphics->TextExtent(rp, testString, strlen(testString), &te);
    IDOS->Printf("MinX: %ld\n", te.te_Extent.MinX);
    IDOS->Printf("MinY: %ld\n", te.te_Extent.MinY);
    IDOS->Printf("MaxX: %ld\n", te.te_Extent.MaxX);
    IDOS->Printf("MaxY: %ld\n", te.te_Extent.MaxY);
    if (te.te_Extent.MinX < 0)
    	x = x - te.te_Extent.MinX;
    IGraphics->Move(rp, x, y);
Re: Wide 'W'
gazelle wrote:Maybe because of a negative kerning of the "W".
If you're kerning, you need a character in front of the W to pair it with. There is no such character in the example, so no kerning of the left of the W should occur.
djg
Re: Wide 'W'
Post by djg »
Since gazelle's suggestion works (here), it seems to me that kerning of the 'W' with its non-existing predecessor does occur when it should not. But that's just a thought, before this I had never heard of kerning.
gazelle
Re: Wide 'W'
Post by gazelle »
I wasn't happy about the use of the term "kerning" but used it for lack of knowing a better one.
It seems to be a bug in the font, because with Verdana or Arial it doesn't happen.
edit:
Ok, after some more tests I found out that with size 15 or 17 (DejaVu Sans) it doesn't happen. So the bug is more likely in the fontengine not the font.
djg
Re: Wide 'W'
Post by djg »
gazelle wrote:I wasn't happy about the use of the term "kerning" but used it for lack of knowing a better one.
edit:
Ok, thanks. So it looks like it is a bug, even if it is a small one. Seems relatively easy to fix. Although I must say, I know very little about it.
Re: Wide 'W'
I can't see that there is any bug here, you *should* check your textextent before rendering text and make any adjustments required for negative values etc.
