Mplayer
Mplayer
vox
Re: Mplayer
Post by vox »
Spectre660 wrote:Seems that mplayer has to be recompiled without altivec support to work.
Got it done and working by following some instructions for G3 macs.
Have used it with open with and custom Command Line option .
Cyrus will have this issue too due to no altivec .
Thanks, what about using VLC?
Future MOS user pon SAM460ex
Re: Mplayer
Re: Mplayer
Re: Mplayer
Spectre660 wrote:Install the default mplayer and Smplayer using apt-get install mplayer smplayer
extract the archive of the mplayer version without altivec .download link below
Copy binaries to /usr/local/bin
delete the default mplayer from /user/bin .
Selct Movie Player in Sound & Video Menu and then Properties.
Change command to mplayer %U. click ok
Mplayer binary compiled withot altivec.
https://dl.dropboxusercontent.com/u/542 ... 4.6.tar.gz
Thanks a lot. I've uploaded your MPlayer: mplayer-SVN-r34540-4.6-sam4x0.tar.gz :)
Elwood
Re: Mplayer
Post by Elwood »
Now what about compiling it for AmigaOS 4 ?
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
Re: Mplayer
vox
Re: Mplayer
Post by vox »
Thanks, such optimized versions really do help on not so strong systems.
Why all Spectre messages are blank?
What about VLC SAM460ex version?
Re: Mplayer
Sam Mplayer2 for Lubuntu 14.04.
http://www.xenosoft.de/mplayer2-2.0-701-gd4c5b7f.tar.gz
copy the mplayer file in the archive to /usr/local/bin
install smplayer and run. (sudo apt-get install smpiayer)
Select options and then preferences from the Smplayer menu.
use the mplayer executable: option to set the mplayer used to /user/local/bin/mplayer .
Select audio.
change the output driver to alsa (0,0 - Cirrus Logic CS4281).
Click on Apply then ok
Drag and drop an audio file or Video file into the Smplayer window.
Re: Mplayer
Smplayer using my Mplayer playing a youtube video.
(449.14 KiB) Downloaded 170 times
