Support for the Nemo board in the official kernel sources
I've created a bug report to add support for our Nemo board to the official kernel sources.
Rgds,
https://bugzilla.kernel.org/show_bug.cgi?id=68811:
Christian Zigotzky 2014-01-16 13:28:54 UTC
Created attachment 122261 [details]
nemo patch
We have created a patch to support the A-EON Nemo board. Nemo uses the AMD/ATI SB600 South Bridge to provide various integrated I/O functions including
SATA/PATA ports, USB and audio. The SB600’s HD Audio controller is connected to an IDT 92HD700 codec. This patch makes the kernel compatible with the SB600
chipset and the HD Audio chip on the Nemo board. It also solved any problems with Radeon HD graphics cards.
Is it possible to integrate this patch to the official kernel sources?
Information about the Nemo board:
CPU: PA Semi Dual-core PA6T-1682M, nominal 2.0GHz (1.8GHz standard) PowerISA™ v2.04+
4x DDR2 RAM slots
10x USB 2.0
1x Gigabit Ethernet
2x PCIe x16 slots (1x16 or 2x8)
2x PCIe x1 slots
1x Xorro slot
2x PCI legacy slots
2x RS232
4x SATA 2 connectors
1x IDE connector
JTAG connector
1x Compact Flash
1x "Xena" 500MHz XMOS XS1-L2 124
http://en.wikipedia.org/wiki/AmigaOne_X1000
http://www.a-eon.com/?page=nemo
http://www.supertuxkart-amiga.de/amiga/x1000.html
Rgds,
