datebrowser.gadget
javierdlr
datebrowser.gadget
Post by javierdlr »
Hi, playing a bit with datebrowser_gd I don't get what 'DATEBROWSER_ShowTitle, FALSE,' should do.
If setting it to FALSE, means that Mon,Tue,Wed,.. strings should be hidden, here It doesn't work :-(
Autodocs says:
DATEBROWSER_ShowTitle (BOOL)
Enables display of the week-day title bar.
Defaults to FALSE.
See example sourcfe code (execute datebrowser.c to compile).
1)The right side has a little gap/space between the datebrowser and the window border, someway to avoid such gap/space?
2)Any way to make "date-buttons" less wide?
TIA
;/* Example
gcc -N -Wall -o DateBrowser dateBrowser.c -lauto -gstabs
quit
*  DateBrowser.c -- DateBrowser class Example.
*  This code opens a window and then creates a datebrowser object.
*  There have been no tags applied, but setting the date and day
*  are possible. See the datebrowser.doc for more details.
#include <gadgets/datebrowser.h>
#include <classes/window.h>
#include <gadgets/layout.h>
#include <proto/intuition.h>
#include <proto/graphics.h>
#include <proto/exec.h>
#include <proto/dos.h>
#include <proto/datebrowser.h>
#include <proto/diskfont.h>
#include <proto/locale.h>
struct Library *DateBrowserBase;
struct DateBrowserIFace *IDateBrowser;
#define OBJ(x) Objects[x]
#define GAD(x) (struct Gadget *)Objects[x]
enum
    GID_MAIN = 0,
    GID_DATEBROWSER,
    GID_LAST
enum
    WID_MAIN=0,
    WID_LAST
enum
    OID_MAIN = 0,
    OID_LAST
void fmtfunct(struct Hook *hook, struct Locale *locale, ULONG ch)
 char *buffer = (char *)hook->h_Data;
 *buffer++ = ch;
 hook->h_Data = (APTR)buffer;
int main(void)
 struct Window *windows[WID_LAST];
 Object *win[OID_LAST], *Objects[GID_LAST];
// CONST_STRPTR weekname[] = {"Su", "Mo", "Tu", "We", "Th", "Fr", "Sa",};
 struct TextAttr ta = {0};
 struct TextFont *font;
 char buffer[20];
 int32 D_today, M_today, Y_today;
 struct Hook *prhook;
 struct DateStamp ds;
 DiskfontBase = IExec->OpenLibrary("diskfont.library", 52);
// if(!DiskfontBase) return FALSE;
 IDiskfont = (struct DiskfontIFace *)IExec->GetInterface(DiskfontBase, "main", 1, NULL);
// if(!IDiskfont) return FALSE;
 ta.ta_Name = "DejaVu Sans Condensed.font";
 ta.ta_YSize = 12;
 font = IDiskfont->OpenDiskFont(&ta);
//IDOS->Printf("Changed to use: '%s', %ld\n",font->tf_Message.mn_Node.ln_Name,font->tf_YSize);
 IDOS->DateStamp(&ds);
 prhook = (struct Hook *)IExec->AllocSysObjectTags(ASOT_HOOK,
                                     ASOHOOK_Entry, fmtfunct,
                                     ASOHOOK_Data, buffer, TAG_DONE);
 ILocale->FormatDate(NULL,"%d", &ds, prhook);
//IDOS->Printf("Dia: %s  ",buffer);
 IDOS->StrToLong(buffer, &D_today);
 ILocale->FormatDate(NULL,"%m", &ds, prhook);
//IDOS->Printf("Mes: %s  ",buffer);
 IDOS->StrToLong(buffer, &M_today);
 ILocale->FormatDate(NULL,"%Y", &ds, prhook);
//IDOS->Printf("Año: %s\n",buffer);
 IDOS->StrToLong(buffer, &Y_today);
 ILocale->FormatDate(NULL,"%^B %Y", &ds, prhook);
//IDOS->Printf("Fecha: %s\n",buffer);
 /* Create the window object. */
 win[OID_MAIN] = IIntuition->NewObject(NULL, "window.class",
//            WA_ScreenTitle, "DateBrowser",
            WA_Title,       buffer,
            WA_Activate,    TRUE,
            WA_DepthGadget, TRUE,
            WA_DragBar,     TRUE,
            WA_CloseGadget, TRUE,
            //WA_SizeGadget,  TRUE,
            WINDOW_Position,    WPOS_CENTERMOUSE,
            WINDOW_ParentGroup, OBJ(GID_MAIN) = IIntuition->NewObject(NULL, "layout.gadget",
             LAYOUT_SpaceOuter, FALSE,
             //LAYOUT_DeferLayout, TRUE,
             LAYOUT_AddChild, OBJ(GID_DATEBROWSER) = IIntuition->NewObject(NULL, "datebrowser.gadget",
              GA_ReadOnly, TRUE,
              GA_TextAttr, ta,
              //DATEBROWSER_ShowTitle, TRUE,
              //DATEBROWSER_DayTitles, weekname,
              DATEBROWSER_Day,   D_today,
              DATEBROWSER_Month, M_today,
              DATEBROWSER_Year,  Y_today,
             TAG_DONE),
            TAG_DONE),
 TAG_END);
 // Window/Object creation sucessful?
 if(win[OID_MAIN])
  // Open the window.
  if( (windows[WID_MAIN] = (struct Window *)IIntuition->IDoMethod(win[OID_MAIN], WM_OPEN)) )
   ULONG wait, signal, done = FALSE, result;
   UWORD code;
   // Obtain the window wait signal mask.
   IIntuition->GetAttr(WINDOW_SigMask, win[OID_MAIN], &signal);
   // Input Event Loop
   while(!done)
    wait = IExec->Wait( signal | SIGBREAKF_CTRL_C);
    if(wait & SIGBREAKF_CTRL_C) done = TRUE;
    else
     while( (result = IIntuition->IDoMethod(win[OID_MAIN], WM_HANDLEINPUT, &code)) != WMHI_LASTMSG )
      switch(result & WMHI_CLASSMASK)
       case WMHI_CLOSEWINDOW:
        windows[WID_MAIN] = NULL;
        done = TRUE;
       break;
  // Disposing of the window object will also close the window if it is
  // already opened, and it will dispose of the layout object attached to it.
  IIntuition->DisposeObject(win[OID_MAIN]);
 IExec->FreeSysObject(ASOT_HOOK, prhook);
 IGraphics->CloseFont(font);
 return(0);
*EDIT: fixed some bugs/typos in DateBrowser source included
salass00
Re: datebrowser.gadget
Post by salass00 »
@javierdlr
If it defaults to FALSE as stated in the autodoc then setting it to FALSE obviously won't do anything. How about you set it to TRUE instead and see if that makes any difference?
javierdlr
Post by javierdlr »
salass00 wrote:@javierdlr
I don't see any change setting it to TRUE.
What should DATEBROWSER_ShowTitle change/show?
