If I try copy icon only , it works inside partition, but not from partition to partition.
I mean .info only and dragging with mouse.
Error while copying 'example'
object not found
Strange.
Other icon related.
If I right click any appicon in WB, I get Grim. Allways.
Before at least with AmSystemRestore, now with AppInfo, old dropicon utility. BTW AppInfo is nice tool, drop in drawer(s) or file(s) and it gives size. Accepts new style icon too.
Unable to snapshot them, naturally.
It is impossible from menu either, snapshot is shaded. Is it supposed to like that ?
System is Peg2/1GHz, 1 Gb mem, 9250 Radeon 256Mb/128bit.
Copying icon solo (.info)
Re: Copying icon solo (.info)
@mlehto
The problem of dragging .info only (no file) occurred with the last update of ASyncWB. I reported the problem back in October 2013 shortly after the AsyncWB update was released. For anyone unfamiliar with the problem, try dragging SYS:System/Shell to another partition or ram: and you will get an error message. Previously, you could drag "bare" icons (no accompanying file) to other partitions with ASyncWB. Some programs include an alternative icon directory with no accompanying files (just .info files) that can't be dragged to another partition either. I don't know what the last ASyncWB update was supposed to fix, but it broke bare icon dragging to another partition. It seems like it should have been an easy fix to change AsyncWB behavior back to it's original behavior for bare icons and that we would have it fixed by now.
I've also seen the "right click on AppIcon" crash reported by someone else but there hasn't been a fix yet. My system is an X1000 but it appears that these problems occur on all OS4 hardware.
@mlehto
I've noticed the same issue when when trying to copy icon files on Workbench. Only affects icons with no file, as you say 'solo' icons like those in icon sets. Copying these worked in the past.
Right clicking app icons on the Workbench causes GrimReaper's here too on A1-500 with OS 4.1 Update 6.
GrimReaper crash log below, occurs when right-clicking SimpleMail's app icon.
Crashlog_ContextMenus_2014-01-08_19-45-05 :
Crash log for task "ContextMenus"
Generated by GrimReaper 53.16
Crash occured in module ContextMenus at address 0x7FB374D0
Register dump:
0: 7FB374C4 60D27BC0 00000000 00000001 00000000 0002F030 0226B180 0226B1F4
8: 00000001 0226DFC6 00000000 00000000 22822024 60EAD194 60EA0000 60EA0000
16: 60EA0000 00000001 60EA0000 E0001000 80000000 60EA0000 60D27BE8 60EA0000
24: 60EA52AC 00000001 60D27CA4 60961F5C 00000000 00000001 60D27CA4 00000000
0: nan 1.32e+07 0.99999 0.5
4: 0 1 148500 64
8: 33 0 1899 33
12: 4.5036e+15 1919 nan -2.85764e+296
16: -9.59894e+257 -3.29643e+38 -2.52612e-10 -2.20923e+307
20: -1.63696e+307 -2.65889e+132 8.7081e-290 -0.854419
24: -5.7711e+26 -8.40827e-296 -1.65072e-270 1
28: 4.5036e+15 4.5036e+15 2.14748e+09 0
Machine State (msr) : 0x0002F030
Condition (cr) : 0x00000001
Instruction Pointer (ip) : 0x7FB374D0
Xtended Exception (xer) : 0xFFFFFFFF
Count (ctr) : 0x80080008
Link (lr) : 0x606DD610
DSI Status (dsisr) : 0x80080009
Data Address (dar) : 0x606DD67C
680x0 emulated registers:
DATA: 62C6C58E 00000003 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 60D279A0
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x7FB374D0 belongs to module "ContextMenus" (HUNK/Kickstart)
Stack trace:
module ContextMenus at 0x7FB374D0 (section 5 @ 0x34AC)
module ContextMenus at 0x7FB374C4 (section 5 @ 0x34A0)
module ContextMenus at 0x7FB36ED0 (section 5 @ 0x2EAC)
native kernel module newlib.library.kmod+0x000020ac
native kernel module newlib.library.kmod+0x00002d5c
native kernel module newlib.library.kmod+0x00002ef0
_start()+0x170 (section 1 @ 0x16C)
native kernel module dos.library.kmod+0x00024f18
native kernel module kernel+0x0003c958
native kernel module kernel+0x0003c9d8
PPC disassembly:
7fb374c8: 419e021c beq- cr7,0x7FB376E4
7fb374cc: 81410024 lwz r10,36(r1)
*7fb374d0: 836a0000 lwz r27,0(r10)
7fb374d4: 801b0000 lwz r0,0(r27)
7fb374d8: 2f800000 cmpwi cr7,r0,0
System information:
CPU
Model: AMCC PPC460EX V1.2
CPU speed: 1100 MHz
FSB speed: 220 MHz
Extensions:
Machine
Machine name: Sam460ex
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:04.0 Vendor 0x1095 Device 0x3114
Range 0: 00001000 - 00001008 (IO)
Range 1: 00001008 - 00001010 (IO)
Range 2: 00001010 - 00001018 (IO)
Range 3: 00001018 - 00001020 (IO)
Range 4: 00001020 - 00001030 (IO)
00:06.0 Vendor 0x126F Device 0x0501
Range 0: 84000000 - 88000000 (MEM)
Range 1: 88000000 - 88200000 (MEM)
05:00.0 Vendor 0xACBE Device 0x0000
06:00.0 Vendor 0x1B21 Device 0x1080
07:00.0 Vendor 0x1412 Device 0x1724
Range 0: 00002000 - 00002020 (IO)
Range 1: 00002080 - 00002100 (IO)
08:00.0 Vendor 0xACBE Device 0x0001
09:00.0 Vendor 0x1002 Device 0x68E1
Range 0: A0000000 - B0000000 (PREF.MEM)
Range 2: B0000000 - B0020000 (MEM)
Range 4: 00002000 - 00002100 (IO)
09:00.1 Vendor 0x1002 Device 0xAA68
Range 0: 00000000 - 00004000 (MEM)
Libraries
0x62ccc758: english-british.language V52.1
0x0226dfc6: exec.library V53.58
0x6ff5e174: vilintuisup.library V0.9
0x6ff5e048: cgxvideo.library V42.1
0x6ff670e0: cybergraphics.library V43.0
0x5d0bb670: ilbm.datatype V53.2
0x5d0bb5d0: Frimagedisplay.mui V20.299
0x5d0bb490: Imagedisplay.mui V20.247
0x5d0bb350: Pendisplay.mui V20.250
0x5e05bb60: String.mui V20.110
0x5e05bac0: Gauge.mui V20.279
0x5e05b980: NListview.mcc V19.91
0x5e05b840: TheButton.mcc V26.14
0x5e05b7a0: TheBarVirt.mcc V26.14
0x5e05b660: TextEditor.mcc V15.43
0x5e05b520: NListtree.mcc V18.43
0x5e05b5c0: NList.mcc V20.136
0x5e05b480: BetterString.mcc V11.26
0x60e88ab0: simplehtml.library V0.21
0x5e070388: update.library V53.12
0x5e05b3e0: fuelgauge.gadget V53.8
0x5d72e2a0: texteditor.gadget V53.20
0x6061b32c: codesets.library V6.16
0x606f79c0: muimaster.library V20.6092
0x607b3668: smartsubdock.docky V50.8
0x61139018: smartbutton.docky V50.8
0x60e785a0: getcolor.gadget V53.9
0x60e74720: gradientslider.gadget V53.6
0x60e74684: colorwheel.gadget V53.6
0x60e854c8: radiobutton.gadget V53.9
0x607b34e8: Spacer.docky V53.2
0x607b32e8: DateTime.docky V52.7
0x60e744a0: slider.gadget V53.13
0x60e74220: getfont.gadget V53.9
0x60e74180: arexx.class V53.3
0x61106f30: getfile.gadget V53.11
0x60cdc5f0: requester.class V53.18
0x61106cb0: bitmap.image V53.9
0x61106c10: integer.gadget V53.10
0x61106990: space.gadget V53.6
0x6115ff38: clicktab.gadget V53.39
0x6fc70eb4: sm502.audio V6.3
0x6fc6dc98: chooser.gadget V53.18
0x61106a30: penmap.image V53.5
0x61106850: checkbox.gadget V53.9
0x6fc6d6d4: filesave.audio V6.3
0x62517ed4: device.audio V6.2
0x6fc70378: listbrowser.gadget V53.61
0x6249f9e0: string.gadget V53.16
0x627208e0: scroller.gadget V53.13
0x6fcbc9e8: Envy24HT.audio V5.23
0x6fc6f548: emulation.library V53.3
0x62d70104: usergroup.library V4.30
0x624be320: bsdsocket.library V4.307
0x62aa1be8: usbhidgate.library V52.2
0x6fcd6d20: mathieeedoubbas.library V52.1
0x62abb55c: textclip.library V52.2
0x6ff04dbc: hid.usbfd V53.8
0x62c45730: button.gadget V53.15
0x62c457d0: glyph.image V53.3
0x62a9e3e0: window.class V53.50
0x62b0fab8: popupmenu.class V53.2
0x62cc0308: popupmenu.library V53.8
0x62c455f0: label.image V53.12
0x6ff5ec78: layout.gadget V53.19
0x62b0f9c0: bevel.image V53.6
0x62c45550: drawlist.image V53.3
0x62c45050: png.datatype V53.6
0x62cbaa54: picture.datatype V53.6
0x62c2e864: asl.library V53.49
0x62c0b17c: ft2.library V53.1
0x6ff0c08c: workbench.library V53.51
0x62d3a9d8: timezone.library V53.8
0x62cc9218: application.library V53.12
0x6ffa899c: commodities.library V53.7
0x62d38140: datatypes.library V53.4
0x62d36730: Picasso96API.library V53.4
0x62d48b70: gadtools.library V53.6
0x62efd6d0: SiliconMotion502.chip V53.10
0x62d46b74: png.iconmodule V53.1
0x6308a0cc: icon.library V53.13
0x62efd3c8: version.library V53.11
0x62d6fbc0: iffparse.library V53.1
0x6ffb9ccc: locale.library V53.6
0x6ff607ac: diskfont.library V53.4
0x6ff04f28: petunia.library V53.4
0x6ff04e68: diskcache.library V3.30
0x6fcd1690: dos.library V53.145
0x6ff07094: usbprivate.library V53.12
0x6ff0b3bc: massstorage.usbfd V53.13
0x6ff0b328: bootkeyboard.usbfd V52.3
0x6ff0b2a8: bootmouse.usbfd V53.1
0x6ff5ee3c: hub.usbfd V53.8
0x6ff5ed8c: usbresource.library V53.12
0x6ff87658: hunk.library V53.4
0x6ff9ddd4: elf.library V53.19
0x6ff8a4d0: intuition.library V53.43
0x6ff44150: rtg.library V53.30
0x6ff98920: RadeonHD.chip V0.57
0x6ff988a4: PCIGraphics.card V53.5
0x6ffaa7a0: keymap.library V53.3
0x6ff85330: layers.library V53.7
0x6ffb8420: graphics.library V53.6
0x6ff87184: nonvolatile.library V53.5
0x6ffab2b8: newlib.library V53.28
0x6ff9e1ac: utility.library V53.5
0x6ffaa0a8: expansion.library V53.1
0x62c6c58e: rexxsyslib.library V53.4 (Legacy)
Devices
0x624710c4: ahi.device V6.6
0x625149b8: ppc460ex_eth.device V53.3
0x6fd683b8: usbdisk.device V53.13
0x6ff9ed10: usbsys.device V53.12
0x6ff879b0: ehci.usbhcd V53.17
0x6ff87910: ohci.usbhcd V53.19
0x6ff87870: uhci.usbhcd V53.12
0x6ff877a4: sii3114ide.device V53.15
0x6ffa8338: console.device V53.1
0x6ff9f3f0: ramdrive.device V52.6
0x6ffaa9ec: input.device V53.4
0x6ff603b4: keyboard.device V53.10
0x6ff9f2d0: timer.device V53.1
Tasks
DepthToFront (Waiting)
Stack: 0x60b5a004 - 0x60b69ffc, pointer @ 0x60b699e0 (Cookie OK)
State: Process (Waiting)
ClickToFront (Waiting)
Stack: 0x60b6e004 - 0x60b7dffc, pointer @ 0x60b7d9f0 (Cookie OK)
input.device (Waiting)
Stack: 0x6ff4c000 - 0x6ff5c000, pointer @ 0x6ff5bf00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fc50004 - 0x6fc52ffc, pointer @ 0x6fc52f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fe92000 - 0x6fe96000, pointer @ 0x6fe95f20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fdd5000 - 0x6fddd000, pointer @ 0x6fddcf20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fe01000 - 0x6fe09000, pointer @ 0x6fe08f20 (Cookie OK)
sii3114ide.device - chip 0 port 0 (Waiting)
Stack: 0x6fe5d000 - 0x6fe65000, pointer @ 0x6fe64f30 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fe0d004 - 0x6fe14ffc, pointer @ 0x6fe14e80 (Cookie OK)
sii3114ide.device - chip 0 port 1 (Waiting)
Stack: 0x6fe35000 - 0x6fe3d000, pointer @ 0x6fe3cf30 (Cookie OK)
Signals: SigRec 0xc0000000, SigWait 0x00008000
ppc460ex_eth Unit 0 (Waiting)
Stack: 0x623ee004 - 0x623fdffc, pointer @ 0x623fde20 (Cookie OK)
Signals: SigRec 0xf6003000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x6274e004 - 0x62755ffc, pointer @ 0x62755e90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x62cd1004 - 0x62ce0ffc, pointer @ 0x62ce0f20 (Cookie OK)
DH0/SmartFilesystem 1.290 (Waiting)
Stack: 0x6fc49004 - 0x6fc4bffc, pointer @ 0x6fc4beb0 (Cookie OK)
RAM/ram-handler 53.3 (Waiting)
Stack: 0x62ebb004 - 0x62ec2ffc, pointer @ 0x62ec2c90 (Cookie OK)
CD0/CDFileSystem 53.4 (Waiting)
Stack: 0x6fc57004 - 0x6fc59ffc, pointer @ 0x6fc59f30 (Cookie OK)
reaper.task (Waiting)
Stack: 0x62e53004 - 0x62e5affc, pointer @ 0x62e5a760 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x6fd0d004 - 0x6fd10ffc, pointer @ 0x6fd10ad0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x80000000
DH1/SmartFilesystem 1.290 (Waiting)
Stack: 0x6fc5e004 - 0x6fc60ffc, pointer @ 0x6fc60eb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x6277a004 - 0x62781ffc, pointer @ 0x62781e90 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x62647004 - 0x62656ffc, pointer @ 0x62656f00 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x62742004 - 0x62749ffc, pointer @ 0x62749e90 (Cookie OK)
HID Consumer (Waiting)
Stack: 0x62524004 - 0x62533ffc, pointer @ 0x62533f20 (Cookie OK)
Stack: 0x625ec004 - 0x625fbffc, pointer @ 0x625fbf20 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x62702004 - 0x62709ffc, pointer @ 0x62709e90 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x6275a004 - 0x62761ffc, pointer @ 0x62761e90 (Cookie OK)
Stack: 0x6265b004 - 0x6266affc, pointer @ 0x6266af00 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x6fd15004 - 0x6fd1cffc, pointer @ 0x6fd1ce90 (Cookie OK)
HID Mouse (Waiting)
Stack: 0x6266f004 - 0x6267effc, pointer @ 0x6267ef20 (Cookie OK)
pager (Waiting)
Stack: 0x62e2f004 - 0x62e4effc, pointer @ 0x62e4ef00 (Cookie OK)
ENV/env-handler 53.2 (Waiting)
Stack: 0x62e16004 - 0x62e18ffc, pointer @ 0x62e18dd0 (Cookie OK)
MassStorage Device Task (Waiting)
Stack: 0x6fcfd000 - 0x6fd05000, pointer @ 0x6fd04e70 (Cookie OK)
Signals: SigRec 0xf3009000, SigWait 0x00000000
URL/launch-handler 53.32 (Waiting)
Stack: 0x62683004 - 0x626fdffc, pointer @ 0x626f8ac0 (Cookie OK)
RANDOM/Random-Handler 52.1 (Waiting)
Stack: 0x6280a004 - 0x62819ffc, pointer @ 0x62819ef0 (Cookie OK)
CON/con-handler 53.1 (Waiting)
Stack: 0x5d572004 - 0x5d581ffc, pointer @ 0x5d581de0 (Cookie OK)
Stack: 0x60c9b004 - 0x60caaffc, pointer @ 0x60caade0 (Cookie OK)
Stack: 0x60cfc004 - 0x60d0bffc, pointer @ 0x60d0bde0 (Cookie OK)
Stack: 0x60d65004 - 0x60d74ffc, pointer @ 0x60d74de0 (Cookie OK)
Stack: 0x60ed7004 - 0x60ee6ffc, pointer @ 0x60ee6de0 (Cookie OK)
Stack: 0x60f9d004 - 0x60facffc, pointer @ 0x60facde0 (Cookie OK)
Stack: 0x60ffd004 - 0x6100cffc, pointer @ 0x6100cde0 (Cookie OK)
Stack: 0x62d02004 - 0x62d11ffc, pointer @ 0x62d11de0 (Cookie OK)
AUDIO/AHI-Handler 6.2 (Waiting)
Stack: 0x62857004 - 0x62866ffc, pointer @ 0x62866ec0 (Cookie OK)
APPDIR/appdir-handler-dos 53.145 (Waiting)
Stack: 0x62e0f004 - 0x62e11ffc, pointer @ 0x62e11da0 (Cookie OK)
Stack: 0x62e6f004 - 0x62e76ffc, pointer @ 0x62e76de0 (Cookie OK)
RAW/con-handler 53.1 (Waiting)
Stack: 0x62ed7004 - 0x62edeffc, pointer @ 0x62edede0 (Cookie OK)
Stack: 0x62ef3004 - 0x62efaffc, pointer @ 0x62efade0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6fc94004 - 0x6fc96ffc, pointer @ 0x6fc96f30 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6fc8d004 - 0x6fc8fffc, pointer @ 0x6fc8fef0 (Cookie OK)
console.device (Waiting)
Stack: 0x6fe6d000 - 0x6fe75000, pointer @ 0x6fe74f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
RexxMaster (Waiting)
Stack: 0x6259d004 - 0x625acffc, pointer @ 0x625acf50 (Cookie OK)
TEXTCLIP/textclip-handler 52.2 (Waiting)
Stack: 0x62786004 - 0x62795ffc, pointer @ 0x62795eb0 (Cookie OK)
Workbench (Waiting)
Stack: 0x624a4004 - 0x624b3ffc, pointer @ 0x624b3ea0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x00008000
Stack: 0x61173004 - 0x61182ffc, pointer @ 0x61182f40 (Cookie OK)
ramlib (Waiting)
Stack: 0x62d75004 - 0x62d8dffc, pointer @ 0x62d8df20 (Cookie OK)
TextEditor.mcc clipboard server (Waiting)
Stack: 0x5d113004 - 0x5d115ffc, pointer @ 0x5d115e90 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x5d931004 - 0x5d933ffc, pointer @ 0x5d933f00 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x5d92a004 - 0x5d92cffc, pointer @ 0x5d92cf00 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x5d923004 - 0x5d925ffc, pointer @ 0x5d925ee0 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x5d5ec004 - 0x5d6e0ffc, pointer @ 0x5d6e0f00 (Cookie OK)
MUI imagespace screen notify (Waiting)
Stack: 0x6068c004 - 0x6069bffc, pointer @ 0x6069bd00 (Cookie OK)
smartbutton.docky (Waiting)
Stack: 0x60718004 - 0x60730ffc, pointer @ 0x60730ec0 (Cookie OK)
ContextMenus Command Dispatcher (Waiting)
Stack: 0x609f0004 - 0x609ffffc, pointer @ 0x609fff40 (Cookie OK)
Stack: 0x6110b004 - 0x6111affc, pointer @ 0x6111adb0 (Cookie OK)
Stack: 0x611c0004 - 0x611cfffc, pointer @ 0x611cff00 (Cookie OK)
AmiDock (Ready)
Stack: 0x61019004 - 0x61028ffc, pointer @ 0x61027e20 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000010
State: Process (Ready)
RinghioServer (Ready)
Stack: 0x60ef3004 - 0x60f12ffc, pointer @ 0x60f123a0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
SimpleMail (Ready)
Stack: 0x5d5a9004 - 0x5d5b8ffc, pointer @ 0x5d5b8e90 (Cookie OK)
Signals: SigRec 0xcfc03000, SigWait 0x01000100
hub.usbfd (Waiting)
Stack: 0x6fd7d004 - 0x6fd84ffc, pointer @ 0x6fd84f00 (Cookie OK)
TCP/IP Control (Waiting)
Stack: 0x61bee004 - 0x61ce2ffc, pointer @ 0x61ce2dc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x00000000
datatypes.library (Waiting)
Stack: 0x62a46004 - 0x62a55ffc, pointer @ 0x62a55f10 (Cookie OK)
MUI-PubScreen-0000000b (Waiting)
Stack: 0x5d077004 - 0x5d086ffc, pointer @ 0x5d086c10 (Cookie OK)
Stack: 0x62c44000 - 0x62c44fa0, pointer @ 0x62c44f10 (Cookie OK)
Background CLI [APPDIR:AmiUpdate] (Waiting)
Stack: 0x622c6004 - 0x623baffc, pointer @ 0x623ba380 (Cookie OK)
Signals: SigRec 0xec001000, SigWait 0x00000100
Granite (Waiting)
Stack: 0x60cb7004 - 0x60cc6ffc, pointer @ 0x60cc6bc0 (Cookie OK)
Signals: SigRec 0xc8008000, SigWait 0x00000100
Stack: 0x61de0004 - 0x61ed4ffc, pointer @ 0x61ed4e10 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
AllKeys (Waiting)
Stack: 0x60d81004 - 0x60d90ffc, pointer @ 0x60d90810 (Cookie OK)
Signals: SigRec 0xf0001000, SigWait 0x00000100
« IPrefs » (Waiting)
Stack: 0x62c4c004 - 0x62c5bffc, pointer @ 0x62c5b980 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
ASYNCWB (Waiting)
Stack: 0x60bb7004 - 0x60bc6ffc, pointer @ 0x60bc6e80 (Cookie OK)
BenchTrash.supervisor (Waiting)
Stack: 0x60c5c004 - 0x60c6bffc, pointer @ 0x60c6bf50 (Cookie OK)
DefIcons (Waiting)
Stack: 0x60fc1004 - 0x60fd0ffc, pointer @ 0x60fd0dc0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x60f5b004 - 0x60f6affc, pointer @ 0x60f6aec0 (Cookie OK)
TCP/IP Superserver (Waiting)
Stack: 0x61ce7004 - 0x61ddbffc, pointer @ 0x61ddb9f0 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
TCP/IP Log (Waiting)
Stack: 0x620cb004 - 0x621bfffc, pointer @ 0x621bff00 (Cookie OK)
Background CLI [SYS:Utilities/FlipPaper/Data/FlipPaper_Auto] (Waiting)
Stack: 0x624d8004 - 0x624e7ffc, pointer @ 0x624e7c50 (Cookie OK)
Signals: SigRec 0xc0001000, SigWait 0x00000100
Background CLI [AmigaKeyRemapper] (Waiting)
Stack: 0x62538004 - 0x62547ffc, pointer @ 0x62547e60 (Cookie OK)
Signals: SigRec 0x00001000, SigWait 0x00000100
ConClip (Waiting)
Stack: 0x62617004 - 0x62626ffc, pointer @ 0x62626eb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x62877004 - 0x62886ffc, pointer @ 0x62886ee0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x62c1b004 - 0x62c2affc, pointer @ 0x62c2af10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd41004 - 0x6fd48ffc, pointer @ 0x6fd48f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd5d004 - 0x6fd64ffc, pointer @ 0x6fd64f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd89004 - 0x6fd90ffc, pointer @ 0x6fd90f00 (Cookie OK)
ContextMenus (Crashed)
Stack: 0x60d18004 - 0x60d27ffc, pointer @ 0x60d27bc0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x80000100
State: Process (Crashed)
Cleaner.process (Waiting)
Stack: 0x60b1b004 - 0x60b2affc, pointer @ 0x60b2aee0 (Cookie OK)
ramlib.support (Waiting)
Stack: 0x62d92004 - 0x62daaffc, pointer @ 0x62daaf00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
dos_signal_server (Waiting)
Stack: 0x6fc9b004 - 0x6fc9dffc, pointer @ 0x6fc9df10 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x62c84004 - 0x62c93ffc, pointer @ 0x62c93d70 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6fca2004 - 0x6fca4ffc, pointer @ 0x6fca4d40 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff86000 - 0x6ff87000, pointer @ 0x6ff86fd0 (Cookie OK)
State: Task (Ready)
Jump to
- General Forums
- ↳ Announcements
- ↳ Public Announcements
- ↳ Forum Questions
- AmigaOS Support
- ↳ AmigaOS Feature Requests
- ↳ General AmigaOS
- ↳ Platform: AmigaOne X5000
- ↳ Platform: AmigaOne X1000
- ↳ Platform: A1222
- ↳ Platform: Pegasos II
- ↳ Platform: AmigaOne 500 and Sam series
- ↳ Platform: AmigaOne XE and MicroA1-C
- ↳ Platform: Classic
- ↳ Localization
- AmigaOS 3.2 Support
- ↳ AmigaOS 3.1.4
- ↳ AmigaOS 3.2
- Games Support
- ↳ Heretic II
- ↳ Freespace
- ↳ Gorky 17
- ↳ Quake II
- ↳ Shogo
- Developer Support
- ↳ General Developer Support
- ↳ SDK Support
- ↳ AmigaOS Documentation Wiki
- Linux Support
- ↳ Platform: AmigaOne 500 and Sam series - Linux Only
- ↳ Platform: AmigaOne A1222 - Linux Only
- ↳ Platform: AmigaOne X1000 - Linux Only
- ↳ Platform: AmigaOne X5000 - Linux Only
