Moving Amidock Icons in the Dock
my_pc_is_amiga
Post by my_pc_is_amiga »
Found an issue when trying to move the icons to a different location in the docky. If I hold down shift and then left click and drag nothing happens. But if I first right click and then use left shift, left mouse button to drag, icon moves...wondering if anybody sees this also...
This is on an X1000 but thinking this wouldn't be limited to this system...
Creols
Re: Moving Amidock Icons in the Dock
Post by Creols »
I think it's not the wright way to put another item in a dock.
Click on Amidock to open its window. There you can add any thing you want (and where you want) by clicking on "Add". Then, enter the path to find the icon.
Creols
AmigaOne XE, µA1, Sam 440ep, Sam Flex 800 MHz, Sam 460 ex, X1000 and more...
Post by zzd10h »
Creols :
I think that it's not to add a new docky to AmiDock, it's simply to move an existing one.
My_pc_is_amiga :
For me, pressing shift before to click works, sometimes not.
Maybe a focus story.
Tested on x1000
my_pc_is_amiga
Creols wrote:I think it's not the wright way to put another item in a dock.
Creols
Yes this issue is moving existing icons in the dock.
