Workbench: Grim Reaper on trying to delete read only files
calicant
Post by calicant »
I'm not sure if this is a bug...
Tested on my SAM 440 with OS4.1 Update 6:
- create a read only file in RAM: (.info is required to reproduce the error):
i.e. from a shell:
copy SYS:Utilities/NotePad ram:
copy SYS:Utilities/NotePad.info ram:
protect RAM:NotePad r
protect RAM:NotePad.info r
- now try to delete it via Workbench contextual menu (AsyncWB is active)
- answer yes to all to the po-pup request to assign delete permission... BOOM!
Re: Workbench: Grim Reaper on trying to delete read only fil
I'm getting one reuqester asking me if i really want to delete and one requester telling me that the object is protected from deletion.
Telling that requester to "Force delete" grims, so i can confirm that
Hidden Text - Click to Show :
Crash log for task "AsyncWB - delete process"
Generated by GrimReaper 53.16
Crash occured in module kernel.debug at address 0x0205B0AC
Register dump:
0: 0205B0AC 504DAC60 419E000C 029735AC 00000000 504DAD40 00000000 00000004
8: 02A84170 00000000 00000183 00000000 44242028 98090001 504DAD32 5F8A0000
16: 504DAD1E 5F8A0000 5F8A65A4 4F88C018 5F8A6538 4F88C028 02069A28 02800000
24: 02A90000 02806720 02800000 02950000 02A95828 504DAD40 00000000 0204C964
0: nan -1.46093e+257 nan -7.54326e+307
4: -7.51272e+237 -1.68828e+260 28 1
8: 262 206 992 262
12: 4.5036e+15 1589 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
Machine State (msr) : 0x0200F030
Condition (cr) : 0x4F8D8608
Instruction Pointer (ip) : 0x0205B0AC
Xtended Exception (xer) : 0x5CDE0CF4
Count (ctr) : 0x6FF6A4D0
Link (lr) : 0x7FB0E918
DSI Status (dsisr) : 0x4F8D83C0
Data Address (dar) : 0x021B0B2C
680x0 emulated registers:
DATA: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 6FFB8700 94232C00 00000000 00000000 00000000 00000000 00000000 504D96E0
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x0205B0AC belongs to module "kernel.debug" (HUNK/Kickstart)
Stack trace:
native kernel module kernel.debug+0x0005b0ac
native kernel module kernel.debug+0x00023060
module AsyncWB at 0x7FA8CC0C (section 5 @ 0x3BE8)
native kernel module dos.library.kmod+0x00024f18
native kernel module kernel.debug+0x000698d0
native kernel module kernel.debug+0x00069950
PPC disassembly:
0205b0a4: 7fe903a6 mtctr r31
0205b0a8: 4e800421 bctrl
*0205b0ac: 813e005c lwz r9,92(r30)
0205b0b0: 801c0020 lwz r0,32(r28)
0205b0b4: 7c090050 sub r0,r0,r9
System information:
CPU
Model: P.A. Semi PWRficient PA6T-1682M VB1
CPU speed: 1800 MHz
FSB speed: 900 MHz
Extensions: altivec
Machine
Machine name: AmigaOne X1000
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:1D.0 Vendor 0x1959 Device 0xA004
Range 0: 007F03F8 - 007F0400 (IO)
00:1D.1 Vendor 0x1959 Device 0xA004
Range 0: 007F02F8 - 007F0300 (IO)
00:1A.0 Vendor 0x1959 Device 0xA007
00:00.0 Vendor 0x1959 Device 0xA001
00:01.0 Vendor 0x1959 Device 0xA009
00:14.3 Vendor 0x1959 Device 0xA005
00:1C.0 Vendor 0x1959 Device 0xA003
Range 0: 007F0200 - 007F0240 (IO)
00:1C.1 Vendor 0x1959 Device 0xA003
Range 0: 007F0240 - 007F0280 (IO)
00:1C.2 Vendor 0x1959 Device 0xA003
Range 0: 007F0280 - 007F02C0 (IO)
00:11.3 Vendor 0x1959 Device 0xA002
00:11.2 Vendor 0x1959 Device 0xA002
00:11.1 Vendor 0x1959 Device 0xA002
00:11.0 Vendor 0x1959 Device 0xA002
00:10.0 Vendor 0x1959 Device 0xA002
00:03.0 Vendor 0x1959 Device 0xA00C
00:04.0 Vendor 0x1959 Device 0xA00A
00:05.0 Vendor 0x1959 Device 0xA00A
00:08.0 Vendor 0x1959 Device 0xA000
00:09.0 Vendor 0x1959 Device 0xA000
00:15.0 Vendor 0x1959 Device 0xA006
00:1B.0 Vendor 0x1959 Device 0xA00B
00:1E.0 Vendor 0x1959 Device 0xA008
Range 0: 007F0400 - 007F0500 (IO)
Range 1: 007F0500 - 007F0600 (IO)
10:00.0 Vendor 0x17A0 Device 0x7163
12:00.0 Vendor 0x1412 Device 0x1724
Range 0: 00004080 - 000040A0 (IO)
Range 1: 00004000 - 00004080 (IO)
0A:12.0 Vendor 0x1002 Device 0x4380
Range 0: 00001040 - 00001048 (IO)
Range 1: 00001058 - 0000105C (IO)
Range 2: 00001048 - 00001050 (IO)
Range 3: 00001050 - 00001054 (IO)
Range 4: 00001000 - 00001010 (IO)
0A:13.0 Vendor 0x1002 Device 0x4387
Range 0: A0208000 - A0209000 (MEM)
0A:13.1 Vendor 0x1002 Device 0x4388
Range 0: A0207000 - A0208000 (MEM)
0A:13.2 Vendor 0x1002 Device 0x4389
Range 0: A0206000 - A0207000 (MEM)
0A:13.3 Vendor 0x1002 Device 0x438A
Range 0: A0204000 - A0205000 (MEM)
0A:13.4 Vendor 0x1002 Device 0x438B
Range 0: A0205000 - A0206000 (MEM)
0A:13.5 Vendor 0x1002 Device 0x4386
Range 0: A0209800 - A0209900 (MEM)
0A:14.0 Vendor 0x1002 Device 0x4385
Range 0: 00001020 - 00001030 (IO)
Range 1: A0209000 - A0209400 (MEM)
0A:14.1 Vendor 0x1002 Device 0x438C
Range 0: 00001038 - 00001040 (IO)
Range 2: 00001030 - 00001038 (IO)
Range 4: 00001010 - 00001020 (IO)
0A:14.2 Vendor 0x1002 Device 0x4383
Range 0: A0200000 - A0204000 (MEM)
0A:14.3 Vendor 0x1002 Device 0x438D
Range 0: 00000000 - 00100000 (MEM)
0A:14.4 Vendor 0x1002 Device 0x4384
0C:05.0 Vendor 0xE159 Device 0x0001
Range 0: 00003100 - 00003200 (IO)
Range 1: A0300000 - A0301000 (MEM)
0C:06.0 Vendor 0x10EC Device 0x8139
Range 0: 00003000 - 00003100 (IO)
Range 1: A0301000 - A0301100 (MEM)
02:00.0 Vendor 0x1002 Device 0x6738
Range 0: 90000000 - A0000000 (PREF.MEM)
Range 2: A0020000 - A0040000 (MEM)
Range 4: 00002000 - 00002100 (IO)
02:00.1 Vendor 0x1002 Device 0xAA88
Range 0: A0040000 - A0044000 (MEM)
Libraries
0x62ac6068: ISO-8859-15.charset V52.1
0x62ac6be8: english_ISO-8859-15.language V52.1
0x02a8b396: exec.library V53.58
0x62b08c28: camdmidi.usbfd V53.5
0x6ff569e4: vilintuisup.library V0.9
0x6ff568b8: cgxvideo.library V42.1
0x6ff330e0: cybergraphics.library V43.0
0x5fe77db8: radiobutton.gadget V53.9
0x5cda7980: 8svx.datatype V53.1
0x5cda78e0: Poppen.mui V20.314
0x5cda77a0: Popimage.mui V20.314
0x5fbf7168: bz2.library V53.3
0x5cda7660: Pixmap.mui V20.55
0x5cda7480: Floattext.mui V20.248
0x5cda72a0: wav.datatype V53.5
0x5cda7340: sound.datatype V53.6
0x5cda70c0: Popmenu.mui V20.225
0x5e2b7730: Lamp.mcc V20.68
0x5e2b7230: Dtpic.mui V20.295
0x5e2b7410: Popasl.mui V20.264
0x5e2b7550: Listtree.mcc V20.145
0x5fa3a894: asyncio.library V50.3
0x5e0f22a8: pthreads.library V53.9
0x5e2b7190: Frimagedisplay.mui V20.298
0x5e2b7050: Imagedisplay.mui V20.246
0x5e318ea0: Pendisplay.mui V20.249
0x5e2b103c: xpkSQSH.library V1.10 (Legacy)
0x5e2b01bc: xpkSMPL.library V1.0 (Legacy)
0x5e3819fc: xpkSHRI.library V2.2 (Legacy)
0x5e3195dc: xpkRLEN.library V1.3 (Legacy)
0x5e2b013c: xpkRAKE.library V1.7 (Legacy)
0x5e31945c: xpkNUKE.library V1.7 (Legacy)
0x5e2b00bc: xpkNONE.library V1.4 (Legacy)
0x5e3185fc: xpkMASH.library V1.98 (Legacy)
0x5e31b868: xpkLZMA.library V52.2
0x5e318452: xpkIMPL.library V1.0 (Legacy)
0x5e3191bc: xpkIDEA.library V1.3 (Legacy)
0x5e3190fc: xpkHUFF.library V0.64 (Legacy)
0x5e31b78c: xpkHFMN.library V1.36 (Legacy)
0x5e31b70c: xpkFRLE.library V1.0 (Legacy)
0x5e28dfac: xpkFEAL.library V1.5 (Legacy)
0x5e28deec: xpkFAST.library V1.10 (Legacy)
0x5e28de2c: xpkENCO.library V1.3 (Legacy)
0x5e28dd6c: xpkDUKE.library V1.6 (Legacy)
0x6233b83c: xpkDLTA.library V0.1 (Legacy)
0x5e7acf1c: xpkCBR0.library V1.0 (Legacy)
0x5fb61f4c: xpkBZP2.library V1.7
0x5e31b50c: xpkBLZW.library V3.0 (Legacy)
0x5e834a30: Gauge.mui V20.278
0x5e834850: TextEditor.mcc V15.43
0x5e8347b0: NBitmap.mcc V15.21
0x5e834670: NBalance.mcc V15.17
0x5e8345d0: NListtree.mcc V18.43
0x5e834530: NFloattext.mcc V19.72
0x5e8343f0: NListview.mcc V19.91
0x5e8342b0: NList.mcc V20.136
0x5e834210: BetterString.mcc V11.26
0x5e834170: TheButton.mcc V26.14
0x5e8340d0: TheBarVirt.mcc V26.14
0x5e834030: TheBar.mcc V26.14
0x61e33b48: amissl_v097g.library V3.7
0x5f5017e8: amisslmaster.library V3.7
0x5f652b30: expat.library V53.3
0x5e6291cc: codesets.library V6.16
0x5fc43b28: update.library V53.12
0x5f802d40: fuelgauge.gadget V53.8
0x5fc45dc0: texteditor.gadget V53.19
0x5fd5ce68: timesync.library V53.7
0x5f802ca0: ilbm.datatype V53.2
0x5fb778a8: RAMDock.docky V50.3
0x5fb77928: GFXDock.docky V50.3
0x5ff1a968: CPUDock.docky V50.2
0x5fe40478: X1kTemp.docky V53.9
0x5ff1ac68: DiskLED.docky V53.1
0x5ff1ace8: DateTime.docky V52.7
0x5f8025c0: Title.mui V20.80
0x5f802480: String.mui V20.109
0x5ff1a668: NetDock.docky V51.4
0x5ff1a3e8: KeymapSwitcher.docky V52.1
0x5ff1a068: SubDock.docky V53.1
0x5ff3df58: Spacer.docky V53.2
0x5ff3db58: Separator.docky V53.2
0x61d909c0: muimaster.library V20.6075
0x5f501f50: slider.gadget V53.13
0x5f501e10: getfont.gadget V53.9
0x5f8a21b8: speedbar.gadget V53.12
0x5f501d70: arexx.class V53.3
0x5f501cd0: getfile.gadget V53.11
0x62b44bc0: requester.class V53.18
0x5f501a50: space.gadget V53.6
0x5f501870: bitmap.image V53.9
0x5f5019b0: integer.gadget V53.10
0x5f5b3038: screenblanker.library V53.3
0x5f8a2e78: clicktab.gadget V53.39
0x5f5b24f4: filesave.audio V6.3
0x5f5b20b8: chooser.gadget V53.18
0x5f89cc20: penmap.image V53.5
0x5f89f784: device.audio V6.2
0x5f89c680: checkbox.gadget V53.9
0x5f89fdb8: hdaudio.audio V6.20
0x61fdae68: Envy24HT.audio V5.23
0x62d765d4: usergroup.library V4.30
0x6ff8f6b8: listbrowser.gadget V53.61
0x61f34020: string.gadget V53.16
0x622fcf30: scroller.gadget V53.13
0x61f323b8: emulation.library V53.3
0x61e6d490: bsdsocket.library V4.302
0x61fda070: mathieeedoubbas.library V52.1
0x6216f5fc: textclip.library V52.2
0x62a4da5c: xadmaster.library V13.1
0x623a12b4: xpkmaster.library V5.2
0x629e987c: hid.usbfd V53.8
0x624f8494: camd.library V53.6
0x62b08af0: button.gadget V53.15
0x62b08b90: glyph.image V53.3
0x6291e840: window.class V53.50
0x627c6348: popupmenu.class V53.2
0x62b2aa58: popupmenu.library V53.8
0x62b089b0: label.image V53.12
0x6fefe5f8: layout.gadget V53.19
0x627c6250: bevel.image V53.6
0x62b08910: drawlist.image V53.3
0x62b084b0: png.datatype V53.6
0x62b2e254: picture.datatype V53.6
0x62a92e44: asl.library V53.49
0x62b2a4f8: timezone.library V53.8
0x62ae7b78: application.library V53.12
0x62aea47c: ft2.library V53.1
0x6fed5c4c: workbench.library V53.51
0x6ffa899c: commodities.library V53.7
0x62b5d140: datatypes.library V53.4
0x62b28740: Picasso96API.library V53.4
0x62b2b100: gadtools.library V53.6
0x62aea084: png.iconmodule V53.1
0x62b3b0cc: icon.library V53.13
0x6fd478c8: version.library V53.11
0x62b768d0: iffparse.library V53.1
0x6ffb9ccc: locale.library V53.6
0x6ff2e7ac: diskfont.library V53.4
0x6fcb43d8: petunia.library V53.3
0x6fcb4318: diskcache.library V3.30
0x6fbe5690: dos.library V53.145
0x6fefe904: usbprivate.library V53.12
0x6feffb3c: massstorage.usbfd V53.13
0x6fefe7bc: hub.usbfd V53.8
0x6feffaa8: bootkeyboard.usbfd V52.3
0x6feffa28: bootmouse.usbfd V53.1
0x6fefe70c: usbresource.library V53.12
0x6ff2d518: hunk.library V53.4
0x6fed1064: elf.library V53.19
0x6ff6a4d0: intuition.library V53.43
0x6ff10150: rtg.library V53.30
0x6ff78ca0: RadeonHD.chip V0.57
0x6ff78c24: PCIGraphics.card V53.5
0x6ffab530: keymap.library V53.5
0x6ff53370: layers.library V53.7
0x6ffb8420: graphics.library V53.6
0x6ff2d044: nonvolatile.library V53.5
0x6ff8c258: newlib.library V53.28
0x6ff8e1ac: utility.library V53.5
0x6ffab0a8: expansion.library V53.1
0x6233c91e: rexxsyslib.library V53.4 (Legacy)
Devices
0x5e0064f4: clipboard.device V53.2
0x61d965c8: rtl8139.device V53.3
0x61dcb414: ahi.device V6.6
0x62503e74: diskimage.device V52.78
0x6ff8ed10: usbsys.device V53.12
0x6ff2daf0: ehci.usbhcd V53.18
0x6ff2da50: ohci.usbhcd V53.19
0x6feff434: sb600sata.device V53.15
0x6ffa8338: console.device V53.1
0x6ff8f3f0: ramdrive.device V52.6
0x6ffab77c: input.device V53.4
0x6ff2e3b4: keyboard.device V53.10
0x6ff8f2d0: timer.device V53.1
Tasks
camdmidi.usbfd (Waiting)
Stack: 0x623cf004 - 0x623daffc, pointer @ 0x623daf40 (Cookie OK)
Signals: SigRec 0x60001000, SigWait 0x00000100
State: Process (Waiting)
ClickToFront (Waiting)
Stack: 0x5f4db004 - 0x5f4eaffc, pointer @ 0x5f4ea9d0 (Cookie OK)
input.device (Waiting)
Stack: 0x6ff18000 - 0x6ff28000, pointer @ 0x6ff27ee0 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fbca004 - 0x6fbccffc, pointer @ 0x6fbccef0 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fe5a000 - 0x6fe5e000, pointer @ 0x6fe5df00 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fdf1000 - 0x6fdf9000, pointer @ 0x6fdf8f00 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fd49000 - 0x6fd51000, pointer @ 0x6fd50f00 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 2 (Waiting)
Stack: 0x6fdad000 - 0x6fdb5000, pointer @ 0x6fdb4f00 (Cookie OK)
OHCI Controller Task Unit 3 (Waiting)
Stack: 0x6fd95000 - 0x6fd9d000, pointer @ 0x6fd9cf00 (Cookie OK)
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fdd9000 - 0x6fde1000, pointer @ 0x6fde0f00 (Cookie OK)
OHCI Controller Task Unit 4 (Waiting)
Stack: 0x6fd61000 - 0x6fd69000, pointer @ 0x6fd68f00 (Cookie OK)
sb600sata.device - chip 0 port 0 (Waiting)
Stack: 0x6fe2d000 - 0x6fe35000, pointer @ 0x6fe34f00 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fdfd004 - 0x6fe04ffc, pointer @ 0x6fe04e30 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x62396004 - 0x6239dffc, pointer @ 0x6239de70 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x6236e004 - 0x6237dffc, pointer @ 0x6237df00 (Cookie OK)
RAM/ram-handler 53.3 (Waiting)
Stack: 0x62ccc004 - 0x62cd3ffc, pointer @ 0x62cd3c70 (Cookie OK)
ICD0/CDFileSystem 53.4 (Waiting)
Stack: 0x620c9004 - 0x620d8ffc, pointer @ 0x620d8f10 (Cookie OK)
ICD1/CDFileSystem 53.4 (Waiting)
Stack: 0x62144004 - 0x62153ffc, pointer @ 0x62153f10 (Cookie OK)
Stack: 0x6308d004 - 0x6308fffc, pointer @ 0x6308ff10 (Cookie OK)
reaper.task (Waiting)
Stack: 0x62c64004 - 0x62c6bffc, pointer @ 0x62c6b740 (Cookie OK)
SATA0/SmartFilesystem 1.290 (Waiting)
Stack: 0x6fbc3004 - 0x6fbc5ffc, pointer @ 0x6fbc5e90 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x6fbad004 - 0x6fbb0ffc, pointer @ 0x6fbb0ab0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x80000000
SATA1/SmartFilesystem 1.290 (Waiting)
Stack: 0x63094004 - 0x63096ffc, pointer @ 0x63096e90 (Cookie OK)
SATA3/SmartFilesystem 1.290 (Waiting)
Stack: 0x630a2004 - 0x630a4ffc, pointer @ 0x630a4e90 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x6238a004 - 0x62391ffc, pointer @ 0x62391e70 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x6234e004 - 0x6235dffc, pointer @ 0x6235dee0 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
SATA5/SmartFilesystem 1.290 (Waiting)
Stack: 0x62df7004 - 0x62df9ffc, pointer @ 0x62df9e90 (Cookie OK)
SATA4/SmartFilesystem 1.290 (Waiting)
Stack: 0x62df0004 - 0x62df2ffc, pointer @ 0x62df2e90 (Cookie OK)
SATA2/SmartFilesystem 1.290 (Waiting)
Stack: 0x6309b004 - 0x6309dffc, pointer @ 0x6309de90 (Cookie OK)
MainIPC0/CrossDOSFileSystem 53.11 (Waiting)
Stack: 0x62415004 - 0x62424ffc, pointer @ 0x62424e90 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
pager (Waiting)
Stack: 0x62c40004 - 0x62c5fffc, pointer @ 0x62c5fec0 (Cookie OK)
ENV/env-handler 52.2 (Waiting)
Stack: 0x62e05004 - 0x62e07ffc, pointer @ 0x62e07dd0 (Cookie OK)
IDF2/FastFileSystem 53.2 (Waiting)
Stack: 0x6223e004 - 0x6224dffc, pointer @ 0x6224deb0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF1/FastFileSystem 53.2 (Waiting)
Stack: 0x621e1004 - 0x621f0ffc, pointer @ 0x621f0eb0 (Cookie OK)
IDF0/FastFileSystem 53.2 (Waiting)
Stack: 0x621a5004 - 0x621b4ffc, pointer @ 0x621b4eb0 (Cookie OK)
IDF3/FastFileSystem 53.2 (Waiting)
Stack: 0x6228a004 - 0x62299ffc, pointer @ 0x62299eb0 (Cookie OK)
rtl8139.device.0 (Waiting)
Stack: 0x5fbc9004 - 0x5fbd8ffc, pointer @ 0x5fbd8f00 (Cookie OK)
Signals: SigRec 0xf0008000, SigWait 0x00000100
Stack: 0x62431004 - 0x62440ffc, pointer @ 0x62440ec0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
URL/launch-handler 53.31 (Waiting)
Stack: 0x61fdf004 - 0x62059ffc, pointer @ 0x62054aa0 (Cookie OK)
RANDOM/Random-Handler 52.1 (Waiting)
Stack: 0x62491004 - 0x624a0ffc, pointer @ 0x624a0ec0 (Cookie OK)
USBPRT/Port-Handler 52.2 (Waiting)
Stack: 0x624ad004 - 0x624bcffc, pointer @ 0x624bcec0 (Cookie OK)
console.device (Waiting)
Stack: 0x6fe35000 - 0x6fe3d000, pointer @ 0x6fe3cf50 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
CON/con-handler 53.1 (Waiting)
Stack: 0x502c3004 - 0x502d2ffc, pointer @ 0x502d2dc0 (Cookie OK)
Signals: SigRec 0xa0000100, SigWait 0x00000000
Stack: 0x5e4de004 - 0x5e4edffc, pointer @ 0x5e4eddc0 (Cookie OK)
Stack: 0x61e3c004 - 0x61e4bffc, pointer @ 0x61e4bdc0 (Cookie OK)
Stack: 0x5e751004 - 0x5e760ffc, pointer @ 0x5e760dc0 (Cookie OK)
Stack: 0x5f3c8004 - 0x5f3d7ffc, pointer @ 0x5f3d7dc0 (Cookie OK)
Stack: 0x5f456004 - 0x5f465ffc, pointer @ 0x5f465dc0 (Cookie OK)
Stack: 0x5f530004 - 0x5f53fffc, pointer @ 0x5f53fdc0 (Cookie OK)
Stack: 0x5f5b9004 - 0x5f5c8ffc, pointer @ 0x5f5c8dc0 (Cookie OK)
Stack: 0x5f67b004 - 0x5f68affc, pointer @ 0x5f68adc0 (Cookie OK)
Stack: 0x62b4c004 - 0x62b5bffc, pointer @ 0x62b5bdc0 (Cookie OK)
AUDIO/AHI-Handler 6.2 (Waiting)
Stack: 0x61f87004 - 0x61f96ffc, pointer @ 0x61f96ea0 (Cookie OK)
Camd Wait Proc (Waiting)
Stack: 0x623f0004 - 0x62408ffc, pointer @ 0x62408ef0 (Cookie OK)
APPDIR/appdir-handler-dos 53.145 (Waiting)
Stack: 0x62dfe004 - 0x62e00ffc, pointer @ 0x62e00d70 (Cookie OK)
Stack: 0x62c80004 - 0x62c87ffc, pointer @ 0x62c87dc0 (Cookie OK)
RAW/con-handler 53.1 (Waiting)
Stack: 0x62ce8004 - 0x62cefffc, pointer @ 0x62cefdc0 (Cookie OK)
Stack: 0x62cf8004 - 0x62cffffc, pointer @ 0x62cffdc0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6fc9a004 - 0x6fc9cffc, pointer @ 0x6fc9cf10 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6fc93004 - 0x6fc95ffc, pointer @ 0x6fc95ed0 (Cookie OK)
RexxMaster (Waiting)
Stack: 0x61ec5004 - 0x61ed4ffc, pointer @ 0x61ed4f30 (Cookie OK)
Stack: 0x6208a004 - 0x6209dffc, pointer @ 0x6209dc00 (Cookie OK)
Stack: 0x62115004 - 0x62128ffc, pointer @ 0x62128c00 (Cookie OK)
Stack: 0x62175004 - 0x62188ffc, pointer @ 0x62188c00 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x621c1004 - 0x621d4ffc, pointer @ 0x621d4c00 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x6221e004 - 0x62231ffc, pointer @ 0x62231c00 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x6225a004 - 0x6226dffc, pointer @ 0x6226dc00 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x622ae004 - 0x622c1ffc, pointer @ 0x622c1c00 (Cookie OK)
TEXTCLIP/textclip-handler 52.2 (Waiting)
Stack: 0x61fbf004 - 0x61fceffc, pointer @ 0x61fcee80 (Cookie OK)
compose.task (Waiting)
Stack: 0x609ac000 - 0x609b4000, pointer @ 0x609b3f10 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000000
Workbench (Waiting)
Stack: 0x61e0b004 - 0x61e1affc, pointer @ 0x61e1ae80 (Cookie OK)
ContextMenus Command Dispatcher (Waiting)
Stack: 0x5fa55004 - 0x5fa64ffc, pointer @ 0x5fa64f20 (Cookie OK)
Stack: 0x5f923004 - 0x5f932ffc, pointer @ 0x5f932f20 (Cookie OK)
ramlib (Waiting)
Stack: 0x62bb6004 - 0x62bceffc, pointer @ 0x62bcef00 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x5e3d9004 - 0x5e3dbffc, pointer @ 0x5e3dbed0 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x61e00004 - 0x61e02ffc, pointer @ 0x61e02eb0 (Cookie OK)
MUI imagespace screen notify (Waiting)
Stack: 0x5ff1f004 - 0x5ff2effc, pointer @ 0x5ff2ece0 (Cookie OK)
TextEditor.mcc clipboard server (Waiting)
Stack: 0x5e3e7004 - 0x5e3e9ffc, pointer @ 0x5e3e9e60 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x5e3e0004 - 0x5e3e2ffc, pointer @ 0x5e3e2ed0 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x5e692004 - 0x5e6b1ffc, pointer @ 0x5e6b1ed0 (Cookie OK)
Stack: 0x5f8ad004 - 0x5f8bcffc, pointer @ 0x5f8bcd80 (Cookie OK)
Stack: 0x60014004 - 0x60023ffc, pointer @ 0x60023ed0 (Cookie OK)
OWB [OWB] (Ready)
Stack: 0x5cf87004 - 0x5d16fffc, pointer @ 0x5d16f7c0 (Cookie OK)
Signals: SigRec 0x07c0d000, SigWait 0x00000180
State: Process (Ready)
AmiDock (Ready)
Stack: 0x5f6a7004 - 0x5f6b6ffc, pointer @ 0x5f6b5e00 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00240010
RinghioServer (Ready)
Stack: 0x5f3dc004 - 0x5f3fbffc, pointer @ 0x5f3fb380 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
[OWB] Timer (Waiting)
Stack: 0x5ce93004 - 0x5cea2ffc, pointer @ 0x5cea2eb0 (Cookie OK)
Signals: SigRec 0x50000000, SigWait 0x00000000
WookieChat (Waiting)
Stack: 0x57d09004 - 0x57d46ffc, pointer @ 0x57d44f20 (Cookie OK)
Signals: SigRec 0x4f801080, SigWait 0x10000100
YAM (Waiting)
Stack: 0x5e4f2004 - 0x5e501ffc, pointer @ 0x5e5019a0 (Cookie OK)
Signals: SigRec 0xffd0f000, SigWait 0x00000110
TCP/IP Control (Waiting)
Stack: 0x5f8e1004 - 0x5f8f0ffc, pointer @ 0x5f8f0da0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x00000000
screenblanker.library timing dispatcher (Waiting)
Stack: 0x5f731004 - 0x5f740ffc, pointer @ 0x5f740e50 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcb9004 - 0x6fcc0ffc, pointer @ 0x6fcc0ee0 (Cookie OK)
[OWB] JavaScriptCore::BlockFree (Waiting)
Stack: 0x5b2e6004 - 0x5b365ffc, pointer @ 0x5b365e20 (Cookie OK)
Background CLI [wait] (Waiting)
Stack: 0x50dbf004 - 0x50dceffc, pointer @ 0x50dceee0 (Cookie OK)
Background CLI [smbfs '//192.168.178.1/FB7390/StoreJet-Transcend-01/'] (Waiting)
Stack: 0x5e7bb004 - 0x5e7caffc, pointer @ 0x5e7ca990 (Cookie OK)
ContextMenus (Waiting)
Stack: 0x5f47a004 - 0x5f489ffc, pointer @ 0x5f489c30 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x0c000000
DRemind (Waiting)
Stack: 0x5f313004 - 0x5f322ffc, pointer @ 0x5f2ec670 (Cookie OK)
Signals: SigRec 0xfe000000, SigWait 0x00000100
[OWB] IconDatabase (Waiting)
Stack: 0x5d5da004 - 0x5d659ffc, pointer @ 0x5d659e80 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
TCP/IP Superserver (Waiting)
Stack: 0x5f8f5004 - 0x5f904ffc, pointer @ 0x5f9049e0 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
DiskImageGUI (Waiting)
Stack: 0x5f35e004 - 0x5f36dffc, pointer @ 0x5f36dda0 (Cookie OK)
Signals: SigRec 0xd7009000, SigWait 0x00000100
Stack: 0x5ff91004 - 0x5ffa0ffc, pointer @ 0x5ffa0dc0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
YAM thread [1] (Waiting)
Stack: 0x5e3af004 - 0x5e3beffc, pointer @ 0x5e3beed0 (Cookie OK)
Signals: SigRec 0x20000000, SigWait 0x00000080
DefIcons (Waiting)
Stack: 0x5f5d5004 - 0x5f5e4ffc, pointer @ 0x5f5e4da0 (Cookie OK)
Shell Process (Waiting)
Stack: 0x50fa0004 - 0x50fafffc, pointer @ 0x50fafb80 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x62a9e004 - 0x62aadffc, pointer @ 0x62aad960 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
Wet (Waiting)
Stack: 0x61e5c004 - 0x61e6bffc, pointer @ 0x61e681c0 (Cookie OK)
Signals: SigRec 0x6e001000, SigWait 0x00000100
YAM thread [2] (Waiting)
Stack: 0x5e388004 - 0x5e397ffc, pointer @ 0x5e397ed0 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x5f55c004 - 0x5f56bffc, pointer @ 0x5f56bbc0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000110
ConClip (Waiting)
Stack: 0x61f4b004 - 0x61f5affc, pointer @ 0x61f5ae90 (Cookie OK)
Stack: 0x62a58000 - 0x62a58fa0, pointer @ 0x62a58ef0 (Cookie OK)
AmiUpdate (Waiting)
Stack: 0x5e70c004 - 0x5e72bffc, pointer @ 0x5e72b360 (Cookie OK)
Signals: SigRec 0xec001000, SigWait 0x01000100
ASYNCWB (Waiting)
Stack: 0x5f5f1004 - 0x5f600ffc, pointer @ 0x5f600e60 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x5f57c004 - 0x5f58bffc, pointer @ 0x5f58bea0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x5ffad004 - 0x5ffbcffc, pointer @ 0x5ffbcee0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x624de004 - 0x624edffc, pointer @ 0x624edec0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x6288d004 - 0x6289cffc, pointer @ 0x6289cef0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x629b4004 - 0x629c3ffc, pointer @ 0x629c3ef0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcd1004 - 0x6fcd8ffc, pointer @ 0x6fcd8ee0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fc1d004 - 0x6fc24ffc, pointer @ 0x6fc24ee0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcf5004 - 0x6fcfcffc, pointer @ 0x6fcfcee0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcc5004 - 0x6fcccffc, pointer @ 0x6fcccee0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcdd004 - 0x6fce4ffc, pointer @ 0x6fce4ee0 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fce9004 - 0x6fcf0ffc, pointer @ 0x6fcf0ee0 (Cookie OK)
AsyncWB Gauge (Waiting)
Stack: 0x50172004 - 0x50185ffc, pointer @ 0x50185e80 (Cookie OK)
Signals: SigRec 0x8000f000, SigWait 0x00000100
ramlib.support (Waiting)
Stack: 0x62bd3004 - 0x62bebffc, pointer @ 0x62bebee0 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
AsyncWB - delete process (Crashed)
Stack: 0x504c7004 - 0x504daffc, pointer @ 0x504dac60 (Cookie OK)
Signals: SigRec 0x00000020, SigWait 0x00000100
State: Process (Crashed)
dos_signal_server (Waiting)
Stack: 0x6fbb5004 - 0x6fbb7ffc, pointer @ 0x6fbb7ef0 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x62acf004 - 0x62adeffc, pointer @ 0x62aded40 (Cookie OK)
Sound_ObjectHandler (Waiting)
Stack: 0x57af7004 - 0x57b34ffc, pointer @ 0x57b34e90 (Cookie OK)
Signals: SigRec 0x4000f000, SigWait 0x00000000
Stack: 0x535b3004 - 0x535f0ffc, pointer @ 0x535f0e90 (Cookie OK)
Stack: 0x5492e004 - 0x5496bffc, pointer @ 0x5496be90 (Cookie OK)
Signals: SigRec 0x4000f000, SigWait 0x00000100
Stack: 0x57a82004 - 0x57a91ffc, pointer @ 0x57a91e90 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6fbbc004 - 0x6fbbeffc, pointer @ 0x6fbbed20 (Cookie OK)
CPUDock_idleTask (Ready)
Stack: 0x5fa4d000 - 0x5fa4e000, pointer @ 0x5fa4deb0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0xc0000000
State: Task (Ready)
idle.task (Ready)
Stack: 0x6ff2c000 - 0x6ff2d000, pointer @ 0x6ff2cfd0 (Cookie OK)
State: Task (Ready)
calicant
Post by calicant »
Also seen on Amiga OS 3.9 ;-)
it does not guru here: file is removed but .info is not deleted.
calicant wrote:Also seen on Amiga OS 3.9 ;-)
Both gets deleted here, then the grim happens (which can be ignored)
Might be because i'm using the debug kernel
I can confirm this. It only crashes if there is an icon, and it does not seem to matter which filesystem is used (RAM:, FFS, etc).
I'll raise a BZ for it.
[edit] BZ #8620. [/edit]
