Kernel 3.13
Kernel 3.13
Hi all,
I've created a Nemo patch for the coming kernel 3.13.
Download:
nemo_3.13.patch.tar.gz
(7.51 KiB) Downloaded 2881 times
Rgds,
Re: Kernel 3.13
Here is the kernel 3.13-rc3 config:
nemo_3.13-rc3.config.tar.gz
(17.48 KiB) Downloaded 1777 times
Re: Kernel 3.13
Unfortunately the Kernel doesn't boot. :(
ggw
Re: Kernel 3.13
Post by ggw »
I have (once again) lost my X1000 LInux.
I am starting over and am facing ALL the same problems I did the other times.
We are all guys and do not tend to be overly explanatory.
One solution for me is to become familiar with the source code.
Is the Linux side of the AmigaX1000's code obtainable by the likes of me?
George Wyche
Re: Kernel 3.13
ggw wrote:I have (once again) lost my X1000 LInux.
I'm sorry about your problems with Linux. :-( The whole A1-X1000 (Nemo) code is in the kernel patch file.
Download: nemo_3.13.patch.tar.gz
ggw
Re: Kernel 3.13
Post by ggw »
A start. Thank you.
George Wyche
Re: Kernel 3.13
There is a big bug present in the PowerPC CPU code of the kernel 3.13. All boards with PA6T are affected (Nemo board, Electra board etc.). Olof Johansson (software engineer from the former P.A. Semi company) helps us to find this bug. Olof is the developer of the PA6T source code in the Linux kernel. He cares about the PA6T code in the kernel. There are a bug report on the bug tracker at kernel.org (Link: Bug 67811 - Kernel 3.13-rc5 doesn't boot with a PA6T cpu). Olof has a lot of P.A. Semi systems with PA6T cpu. I hope he can solve the problem.
Rgds,
Re: Kernel 3.13
Olof has solved the problem. I've compilied the RC 6 of kernel 3.13 with Olof's fixes. You could test the RC 6 if you like.
Download: vmlinux-3.13-rc6-AmigaOneX1000.tar.bz2
Note: The Radeon Dynamic Power Management doesn't work. You have to add the argument and the value "radeon.dpm=0" to the bootargs. For example:
setenv bootargs "root=/dev/sda4 radeon.dpm=0"
Rgds,
Re: Kernel 3.13
(210.46 KiB) Downloaded 367 times
Re: Kernel 3.13
The RC 7 is available for testing: vmlinux-3.13-rc7-AmigaOneX1000.tar.bz2
(246.04 KiB) Downloaded 324 times
