Problem applying Update 6
Amigaphile
Post by Amigaphile »
I have an AmigaOne XE/G4 on which I recently installed AmigaOS 4.1 Update 5; I have downloaded Update 6 and I'm trying to install it, but I get a message from the installer, saying "Required object is missing."
The only thing that might be a clue to what is missing is the title of the message window, "ELF Library".
How can I determine what is missing, and how can I correct the situation?
Hypex
Re: Problem applying Update 6
Post by Hypex »
Did you unpack using UnArc? And your Update 5 volume was okay before, no rogue libraries? I've seen this sort of thing happen with old libraries installed by accident.
