Installation Instructions for the new Iceweasel and Icedove
There are new versions of Iceweasel and Icedove for Debian 7.2 and Debian Sid. Here are the installation instructions for the new Mozilla software products.
Debian 7.2/Sid:
Put the following line in /etc/apt/sources.list:
deb http://ftp.us.debian.org/debian experimental main
Then execute the following commands:
apt-get update
apt-get install -t experimental iceweasel
apt-get install -t experimental icedove
Have a lot of fun with the new Iceweasel and Icedove.
All the best,
Re: Installation Instructions for the new Iceweasel and Iced
Screenshot of Iceweasel 25.0 and Icedove 24.0 on Debian Sid:
(303.9 KiB) Downloaded 286 times
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Thanks Christian, excellent work as usual. :-)
Trevor
I'm just Breezin'
If the pictures have wrong colors, then modify the configuration with about:config. Find the worth image.high_quality_downscaling.enabled and set it to false.
If Iceweasel (Firefox) and Icedove (Thunderbird) have another Font in the menus and dialogue boxes than the desktop environment, then you have to create the file .fonts.conf in the home directory.
<?xml version="1.0"?>
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
<match target="font" >
  <edit mode="assign" name="rgba" >
   <const>rgb</const>
  </edit>
</match>
  <edit mode="assign" name="hinting" >
   <bool>true</bool>
  </edit>
</match>
  <edit mode="assign" name="hintstyle" >
   <const>hintfull</const>
  </edit>
</match>
  <edit mode="assign" name="antialias" >
   <bool>true</bool>
  </edit>
</match>
</fontconfig>
If this file exist, then the Firefox use the font configuration from the desktop environment.
