X1000 Cell Battery
sundown
X1000 Cell Battery
Post by sundown »
No known issue with it yet, but was wondering what to expect if it dies or is removed. Will we lose the CFE variables where the system is un-bootable? Maybe a question for Varisys.
Ken
LyleHaze
Re: X1000 Cell Battery
Post by LyleHaze »
I am not an employee of Varisys, but page 12 of the tech ref manual says that the battery is for "Real Time Clock and non-volatile CMOS Memory". There's also a jumper for clearing the memory..
Based on that, I'd say that we will lose data if the battery is gone for long.
I welcome corrections if I got anything wrong.
[edit]
I wonder if saving the output of "c:nvgetvar" will give us everything we need for a restore?
LyleHaze wrote:I am not an employee of Varisys, but page 12 of the tech ref manual says that the battery is for "Real Time Clock and non-volatile CMOS Memory". There's also a jumper for clearing the memory..
[edit]
In the Firmware and Booting Guide on page 14, chapter 6 is the "default CFE configuration" printed.
So it should be easy to type these few commands after an emergency...at least it will get you up and running again
People are dying.
How dare you!
– Greta Thunberg
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Can I suggest we ask Steven Solie, who has just changed the cell battery on his AmigaONE X1000. ;-)
Trevor
I'm just Breezin'
LyleHaze wrote:I wonder if saving the output of "c:nvgetvar" will give us everything we need for a restore?
It should, as far as I can see. Although I'd suggest printing it, not just saving it - if you need it, you probably won't be able to get at it on the HD (at least unless you save it on a different machine).
trevordick wrote:Can I suggest we ask Steven Solie, who has just changed the cell battery on his AmigaONE X1000. ;-)
Trevor
Did he really have to send it to an auto repair shop for that job? Or is that just a nasty rumour?
Severin
Post by Severin »
I changed my battery today as I'd been having similar problems so ssolie (not starting, just a dead blank screen cured by switching off the PSU for a few seconds, also CFE reboot loops.
The battery was out for under 10 seconds andI didn't loose any settings.
The only problem I had was a CFE error saying it couldn't load amigaboot.of due to insufficient memory. I popped out the ram modult which had a layer of dust on it from the cpu fan. cleaned it up and cleaned out the socket with a brush, same problem, tried it in the other side socket, same problem. I eventually tracked down the problem...
CFE LIES... it wasn't memory, I'd knocked the power lead out of the harddrive when changing the battery. Now all is well and the system seems to be booting better.
Severin
Post by Severin »
tonyw wrote:Did he really have to send it to an auto repair shop for that job? Or is that just a nasty rumour?
Yes he did take it in for repair (I met him the after he took it to amigakit), it was thought to be a problem with the CPU mount but turned out to be the bettery which is good news for all of us.
Slayer
Post by Slayer »
yes
CFE just says things like that when it cant execute something I guess
it was decided that was better than what?
My last X1000 system was set up for a first contact user and as such
doesnt expect my compact flash card so I always get that type of error
before I type the correct
boot -fatfs cf0:amigaboot.of
sometimes I typo and leave off the end f I get the same error message
my logic behind not changing it is so I remember how to navigate CFE
its nice to know what to type for debugging etc
of course thats just me
ssolie
Post by ssolie »
Severin wrote:Yes he did take it in for repair (I met him the after he took it to amigakit), it was thought to be a problem with the CPU mount but turned out to be the bettery which is good news for all of us.
Thank goodness it was something much simpler. An entry has already been added to the wiki so others don't have to suffer.
On a somewhat related topic, I was working on Timberwolf last night via Ubuntu on the X1000. A HUGE THANKS to our local Linux experts for making Ubuntu "just work" so I can focus on Timberwolf. Kudos! I have the code and I was just finishing up the cross-compiler dev environment. I plan to send out a binary release once I get it all working to establish a baseline. Then we can add some 3rd party devs to the team and get moving again. I'll blog when the time is right.
