Hello,
I have 2 questions related to RMB and AmiDock.
1) when I RMB on AmiDock, all the dockies are frozen (for example, CPUClock). Of course, when I RMB on Workbench, AmiDock don't stop to work.
Is it normal ? Is it deactivable ?
2) Is this RMB event trappable in C ?
I can use DOCKYSET_DoubleClick, DOCKYSET_Click, DOCKYSET_ObjectClick and DOCKYSET_DockClick to detect left mouse click but I find nothing for Right mouse button.
My problem is that for 2 of my dockies
-CPUDock (try to put cpuwatcher in docky)
-NetDock (try to open a MUI window, without event loop)
it crashs AmiDock in CLASSES:popumenu.class as soon that I RMB (for my NetDock, crashs only when the external window is opened).
http://zzd10h.amiga-ng.org/NetDock/NetD ... _KO_01.jpg
http://zzd10h.amiga-ng.org/NetDock/NetD ... _KO_02.jpg
If I close the extern window (by detecting a DockCLick or ObjectCLick) it works but it will be better to be able to detect Right click
Thanks for your help
AmiDock & RMB
AmiDock & RMB
- javierdlr
Re: AmiDock & RMB
You can download KeymapSwitcher, It has Context menus (RMB) support/enabled.
BOOL _docky_DockyGet(struct DockyIFace *Self, uint32 msgType, uint32 *msgData)
case DOCKYGET_ContextMenu: // RMB is pressed
Object *contextMenu = (Object *)msgData;
#ifdef DDEBUG
IDOS->Printf("[DOCKYGET_ContextMenu]\n");
#endif
Object *subMenu = IIntuition->NewObject(NULL, "popupmenu.class", TAG_END);
Object *itemSM = IIntuition->NewObject(NULL, "popupmenuitem.class",
PMIA_Title, "Mode",
PMIA_SubMenu, subMenu,
TAG_END);
Object *itemS1 = IIntuition->NewObject(NULL, "popupmenuitem.class",
PMIA_Title, "PopUp",
PMIA_ID, MENU_OPT1,
PMIA_CheckIt, TRUE,
PMIA_Checked, !WinMode,
TAG_END);
Object *itemS2 = IIntuition->NewObject(NULL, "popupmenuitem.class",
PMIA_Title, "Window",
PMIA_ID, MENU_OPT2,
PMIA_CheckIt, TRUE,
PMIA_Checked, WinMode,
TAG_END);
Object *item3 = IIntuition->NewObject(NULL, "popupmenuitem.class",
PMIA_Title, "Settings...",
PMIA_ID, MENU_PREFS,
TAG_END);
// Object *itemBar = IIntuition->NewObject(NULL, "popupmenuitem.class", PMIA_Title,~0, TAG_END);
IIntuition->IDoMethod(subMenu, OM_ADDMEMBER, itemS1); // mode popup
IIntuition->IDoMethod(subMenu, OM_ADDMEMBER, itemS2); // mode window
IIntuition->IDoMethod(contextMenu, OM_ADDMEMBER, itemSM); // Submenu string 'Mode'
if(WinMode) IIntuition->IDoMethod(contextMenu, OM_ADDMEMBER, item3); // Settings...
// IIntuition->IDoMethod(contextMenu, OM_ADDMEMBER, itemBar);
break;
BOOL _docky_DockySet(struct DockyIFace *Self, uint32 msgType, uint32 msgData)
struct DockyData *dd = (struct DockyData *)((uint32)Self - Self->Data.NegativeSize);
case DOCKYSET_ContextMenuResult: // objetc/option from RMB menu choosed
Object *o = (Object *)msgData;
#ifdef DOCKY_DEBUG
IDOS->Printf("[DOCKYSET_ContextMenuResult]\n");
#endif
if(o)
IIntuition->GetAttr(PMIA_ID, o, (uint32 *)&dd->km_item);
#ifdef DDEBUG
IDOS->Printf("KeyMapSwitcher: item=%ld\n",dd->km_item);
#endif
switch(dd->km_item)
case MENU_OPT1: WinMode = FALSE; // PopUp mode
break;
case MENU_OPT2: WinMode = TRUE; // Window mode
break;
case MENU_PREFS:
break;
} // END switch(dd-km->item)
} // END if(o)..
break;
Re: AmiDock & RMB
Oh...i thought you two were already in contact
Yeah, docky powers combined
Re: AmiDock & RMB
Thank you Javier,
I saw that yours worked perfectly.
but how do you detect if the mouse button is left or right one ?
EDIT, ah yes I understood, in case DOCKYGET_ContextMenu: thx will try tomorrow
By the way, I succeed to make MUI window works with NetDock by closing the MUI external window when mouse is outside the docky (DOCKYSET_MouseIsOverDocky)
Now it works, my MUI window is opened and closed if the mouse is inside or outside NetDock
edit : better to have info window beside the mouse cursor (with Thomas Claus NetDock pictures set)
http://zzd10h.amiga-ng.org/NetDock/NetD ... iInfo2.jpg
I have to see if it's applicable to CPUDocky too, tomorrow is another day...
Edit : I forgot to say that I auto-close the MUI window when I click inside my docky to avoid the çrash, of course.
Raziel, yes but as Javier doesn't seems to encounter my specific problem, I prefered to ask...
To sum up, is somebody knows
1) why AmiDock freezes himself when RMB is pressed ?
2) how to detect RMB in AmiDock ?
Thank you
Thank you
